Old 08-09-2010, 12:07 PM   #1
djpink1947
djpink1947's Avatar
Default Distributor is stuck
Hello: I have a friend with a 1973 Torino and he would like to time the car because he wants to install a Petronix ignition. Trouble is he can get the distributor out or to move at all. He's tried everthing but, no luck. Anyone got any idea's out there as how to loosen up this part and get it to work?? DJP
djpink1947 is offline   Reply With Quote
Old 08-09-2010, 12:34 PM   #2
BOSSY
BOSSY's Avatar
Default Re: Distributor is stuck
A lot of PB BLASTER, time, tap back a forth, small pipe wrench. The aluminum has oxidized into the cast iron. Their should be an O ring on it. Good luck.
BOSSY
BOSSY is offline   Reply With Quote
Old 08-09-2010, 01:15 PM   #3
Frank The Plumber
Ditto, gently
Frank The Plumber is offline   Reply With Quote
Old 08-09-2010, 01:29 PM   #4
ford1
there is a rubber "o" ring on the dist shaft. over time it is heated and kind of welds its self to the dist, get a long pry bar or a crow bar and a rubber mallet, find a place under the dist that you can pry up on with out breaking any thing, pry up while tapping on the vacuum advance to get it to move, go easy, you dont want to break any thing
ford1 is offline   Reply With Quote
Old 08-09-2010, 02:50 PM   #5
JeffB2
JeffB2's Avatar
When you re-install coat it with anti-seize so you don't go thru this again.
JeffB2 is offline   Reply With Quote
Old 08-09-2010, 08:49 PM   #6
paul2748
paul2748's Avatar
He's right about the penetrant, soak, soak and soak some more. Try working it back and forth. The early YBlock distributors had no O ring, that came later. Most of the replacements have the O ring.
Old 08-10-2010, 09:21 AM   #7
dav
I had one stuck on my vette and I also soaked it with PB Blaster for a few days. I had a long open end wrench as the vette dist had a square part on the lower part of the shaft I just kept hitting the wrench with a hammer back and fourth until it moved.
dav is offline   Reply With Quote
Old 08-14-2010, 09:34 AM   #8
ford1
paul 2748, i think your wrong about the "O" ring, had a 55 and 56 y block and they both had the dist "O" ring, both new from the dealer
Old 08-16-2010, 02:24 PM   #9
butchbov
butchbov's Avatar
It took about 2 weeks & a lot of Kroil to loosen up the dizzy in my 59 292. I still don't have it out, but at least I can adjust the timing.
Butch
In a world filled with stress it is better to give than to receive.
butchbov is offline   Reply With Quote
Old 08-16-2010, 07:52 PM   #10
paul2748
paul2748's Avatar
When you get it out, let us know if there is an O Ring on it. I think the reason they got stuck was because there was metal to metal contact. An O Ring would prevent this. But then again, I could be wrong.
Old 08-17-2010, 12:28 PM   #11
Dave72dt
I've seen it on later engines that definitely had the o-ring. Back when these engines were in for a tuneup every so many thousands of miles, the dist got turned and/or removed more frequently. With elecronics and no points, some of these newer engines never have the dist turned in their lifetime.
Dave72dt is offline   Reply With Quote
Old 08-21-2010, 07:36 PM   #12
davis57ford
davis57ford's Avatar
I used pb blaster for qabout a week straight while driving it 2-3 times a day took a piece of oak wood about 1 inch by 12 inches and kept taping on it with a dead blow and it finally broke loose, good luck!
davis57ford is offline   Reply With Quote
Old 09-10-2010, 12:52 PM   #13
Pamlico
Pamlico's Avatar
If you are just installing the Pertronix kit, there is no need to pull the distributor.
Pamlico is offline   Reply With Quote
Old 09-15-2010, 07:21 AM   #14
JoeGermann
JoeGermann's Avatar
You might find that making a 50/50 mix of ATF and Acetone will work a LOT better than PB blaster or any other similar product. The key is patience and a BIG hammer. (just kidding about the hammer)
Good luck,
Joe
JoeGermann is offline   Reply With Quote
Old 09-15-2010, 11:11 PM   #15
parklane
parklane's Avatar
Good luck,
Joe
Ya, that stuff works better than anything else I've ever tried. Cheaper too.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
