Old 03-19-2013, 01:39 PM   #1
msmaron
msmaron's Avatar
Default Rebuilding Roadster Door Latches info needed??
Anyone know of any publication in any of the books or mags that has the information in it about rebuilding Roadster Door latches...thanks all?
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 03-20-2013, 04:14 PM   #2
msmaron
msmaron's Avatar
Default Re: Rebuilding Roadster Door Latches info needed??
No one is aware of any publication that has information in it...common folks??
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 03-20-2013, 05:24 PM   #3
darrylkmc
darrylkmc's Avatar
msmaron,
On the two that I have done, there were a few places that were spot welded or pressed to hold the halves together, carefully ground these areas down until the halves separated.
I then built up with weld any worn areas and filed or ground these areas until things were back to normal dimensions.
I was able to locate some springs that I cut down to get the correct length as they were a bit long. Put it back together and tack welded the ground down spots and softpacked my tacks until smooth.
They both work like a charm. Hope this helps, I am doing this from memory, as I recall it was not a difficult task.
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 03-20-2013, 05:29 PM   #4
msmaron
msmaron's Avatar
Darryl thank you for that
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 03-21-2013, 01:24 PM   #5
Richard Redmond
Richard Redmond's Avatar
Hi Mark,
I can't claim to be expert, but I restored a 29 Roadster and have owned it for about 4 years. I built up a fair library of books, articles and web site links but haven't come across a 'how to do it' on door latches.
Richard Redmond is offline   Reply With Quote
Old 03-21-2013, 02:02 PM   #6
Bill Underwood
I rebuild those and alot of latches. I usually replace the springs with one a bit less stiff. If allows the doors to close easier. I know Henry knows best but I have never had a downside to doing this. A concern is those doors have been know to pop open when the body twists. But no reports to date. Having a milling mahine sure helps, too. Build up the plunger wear and mill it down.
BTW, I just get the replacement springs at an ACE hdwe or anywhere they have the assortment drawers.
Bill Underwood is offline   Reply With Quote
