Old 03-13-2013, 07:48 PM   #1
sgwilson904
Default Big mystery finally solved...and who deserves the prize?
About six weeks ago, I posted the thread “Who Can Solve This Mystery? Win a Prize?” Astoundingly, it was viewed more than 11,000 times and more than 200 of you wrote replies with suggestions to solve the problem that was causing my 29 CC P/U to intermittently sputter, backfire and fail to run more than about 6 mph. Sometimes it started up and ran just fine, most of the time it did not. You could never depend on it to get you there—and back.
First, thanks to all of you who pitched in with ideas. As I reported (and will discuss in detail below) several fellow club members spent many hours trying our best to follow all your suggestions, except Brent’s ideas to check for loose lugnuts on the left rear wheel and make sure the radiator coolant had the proper mixture…those were jokes, right?
After weeks of trying virtually everything, we were just never able to identify the real problem and resolve it. In sheer desperation, I finally turned it over to the fellow many of us call “The Guru” here in our local club in Jacksonville, FL. H.L. Chavin would call him a “Model A Whisperer” with the patience and know-how to sleuth out the problem.
I’m happy to report that it appears the mystery has finally been solved! And so what was it?
According to "The Whisperer": The grounding strap from the battery to the frame was not always providing sufficient ground to provide ample and consistent juice to the distributor. Sometimes it worked just fine—like on my long drive to coastal Georgia where the truck ran fine for 110 miles before it suddenly started acting up—and then other times you couldn’t even get the thing to start.
The local whispering guru says a continuity test with a meter confirmed this. (For the benefit of us all who have experienced a similar perplexing problem, he’s planning to write a more-detailed explanation later here in this same thread.)
So what about the prize I offered in my total frustration to find the answer? Who should get the prize?
Turns out, after scouring all the suggestions previously posted, it’s not so easy to select the winner. Without sending you back through 20 dozen postings, here are the people who got CLOSE to identifying the problem.
The g-word was actually first used in Post #4 by “Brent in 10-uh-C” who suggested checking for a blue spark from the coil wire to a ground source when the engine cranks. This didn’t resolve it because we GOT the spark when the ground strap was working okay and the engine was running as it should.
In Post #19, “Modelacoupe3” suggested a ground problem caused by the wire to the upper plate of the distributor. We changed that but no ground problem there. Eventually, we even dropped in an all-new distributor and still the engine didn’t run right.
Then, in Post #41, “Mike V,” a senior member from South Florida, wrote on January 27: “Grounding to the engine.” He went on to guess the fuel line was acting as an engine ground which was conducting heat to the extent it was causing the fuel to turn to vapor. Although he clearly mentioned grounding, we took it to be a contributing factor to "the real problem" which he believed to be the dreaded vapor lock. He suggested “place a cable from the chassis to the engine and see what happens.”
On the same day, “MikeK” from the Windy City offered a host of suggestions to ascertain whether root of the problem was fuel or electrical. In his paragraph on electrical, he wrote: “You may also experience that type of behavior if you are running on straight generator, with the connection to the battery lost.” He went to suggest: “Remove/clean- frame to ground strap bolt, both battery terminals, heavy cable to starter, wiring from cutout to starter switch, wiring to terminal box” and maybe, he suggested, there could even be a problem with internal connections between cells inside the battery. But since I long ago replaced the generator with an alternator, we didn’t think Mike’s hypothesis was valid in this case.
After 101 posts, “Mike V” in Florida, recalled and summarized many earlier suggestions and asked if those were followed, including. “Was the ground to the engine checked?” Mike was sure “We can get this!” We kept on looking.
24 posts later, H.L. Chavin hit on the ground problem again, but we all got a little sidetracked because his theory was presented in the context of bad grounding causing vapor lock as the real heart of my problem. H.L. said this could be checked by splicing a short piece of rubber hose into the fuel line, ostensibly to reduce heating the fuel in the line. We replaced the copper fuel line with a steel one but problem continued. A few posts later, he also asked “possible new painted engine blocking ground?” Nope, paint wasn’t my problem.
Later, H.L. did suggest adding a second ground strap (again as another possible step to resolve a vapor lock). Here again, I was sidetracked because the engine would often run just fine for a prolonged period. None of us could see how vapor lock that was caused by lack of ground (or anything else) could be my problem.
And then, on March 1 (Post #236), Rock Hornbuckle in Auburn, Washington jumped into the dispute about whether the coil needs a ground. It was in that context he suggested: With an ohm meter, check the readings between the engine/frame, engine/coil should read open, engine/battery ground post, battery ground post/generator ground. If all the readings are the same, you don't have a grounding problem. Do these checks cold, then do the checks when the engine is hot and quits.”
Rock went on to sound a little like my college physics professor (gawd, I hated that class) but added an explanation of how this problem could have caused my problem to be so intermittent: “I know this sounds crazy, but electrical resistance in your engine block and wiring changes with temperature. If you have any bad wires (thinning through age) the slightest heat rise will affect its current carrying capabilities. The same holds true for any bad or loose or intermittent ground connections.”
The Whisperer here has taken the truck on a long drive to St. Augustine. He reports it ran just fine except for some brief sputtering which he says was crap in the fuel and once that was out, it resumed running as it should.
Hoping it is finally no longer possessed, I'm picking it up and taking it on a club tour event this coming Sunday. I'll report how it does on my test-drive! Meanwhile, watch for the more-technical details of what got me back on the road. I think it could be a big help to many.
Now, as to the prize:
Brent log ago suggested an ARC (Answer Review Committee). So what do y’all think? Who deserves the prize? And what should it be? How about the old ground strap that looks like it WAS the heart of my problem?
As always, suggestions warmly welcomed...and thanks again to all of you for your patience!
sgwilson904 is offline   Reply With Quote
Old 03-13-2013, 08:05 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Default Re: Big mystery finally solved...and who deserves the prize?
If you think I won, I donate my prize back you. Just knowing what finally solved your problem is prize enough for me.
Old 03-13-2013, 08:09 PM   #3
luckyal
Okay did I miss it ? What was the prize ???
Al
luckyal is offline   Reply With Quote
Old 03-13-2013, 08:38 PM   #4
J Franklin
J Franklin's Avatar
A member of our club had a woven ground strap that looked pristine and had no continuity end to end. the copper had corroded under the crimp.
Old 03-13-2013, 09:15 PM   #5
Gary WA
Gary WA's Avatar
Glad it's back to driving!!! Boy will I sleep tonight! Been awake for weeks thinking about this problem!!! Good Job All. And thanks for the report...
www.whidbeymodelaclub.com
Old 03-13-2013, 09:43 PM   #6
MikeK
MikeK's Avatar
Thank you very much for reporting the final problem/solution! Far too many threads never show the final resolve.
I humbly suggest that you also post a short statement with the resolve at the end of the original thread. That may save some head-banging by future readers using the 'search' to solve their own problems.
MikeK is offline   Reply With Quote
Old 03-13-2013, 09:43 PM   #7
Purdy Swoft
Purdy Swoft's Avatar
I didn't reply to the thread. I hope that the problem is solved, I've got my doubts. I've got to lean toward Brents idea that the mix could be wrong in the radiator. After all, Tom Wesenberg runs a 50/50 mix year round. Insert smiley face. Sorry, I just couldn't resist.
Old 03-13-2013, 09:51 PM   #8
Rock Hornbuckle
Rock Hornbuckle's Avatar
sgwilson904, So glad you found the culprit....by the way, I did teach at the college level!
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 03-14-2013, 01:26 AM   #9
H. L. Chauvin
Hi Steve,
In my sincere opinion, as a very refined gentleman, you already "shared" the prize among "all" of us, by:
1. First, reporting that it is finally fixed.
2. Showing all the way through, that you never gave up typing detailed messages & brought out tons of written Model A experiences from many others whereby we all witnessed that we still have many wonderful true Americans willing to assist.
3. You came back to share & write in detail exactly what was found. So many American One-Way-Street-Individuals today are so brain washed with Government hand-outs etc., that they no longer have the word "thanks" in their vocabulary.
4. How about this? After all of your efforts, devout appreciation, and kind words, maybe you should tell us what you need for your Model A & we can look to see if we can mail "you" a prize!
H. L. Chauvin is offline   Reply With Quote
Old 03-14-2013, 07:51 AM   #10
sgwilson904
Originally Posted by MikeK View Post
...I humbly suggest that you also post a short statement with the resolve at the end of the original thread. That may save some head-banging by future readers using the 'search' to solve their own problems.
Great idea, Mike, and I have just done so! Thanks again!
Old 03-14-2013, 08:06 AM   #11
Al 29Tudor
Al 29Tudor's Avatar
Great thread, group participation, persistence and results. I think the offending ground strap should be mounted to a plaque and placed in the clubhouse or be presented to a member each year after a foolish blunder or an elusive problem like this one. What a great site!
Al Leach
Al 29Tudor is offline   Reply With Quote
Old 03-14-2013, 07:18 PM   #12
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Dog here, If nobody wants the prize, I'll take it! I've never got a prize for anything! P.M. for my address! (It's the same as Bill's address.) Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 03-14-2013, 09:40 PM   #13
Chris in WNC
Chris in WNC's Avatar
seems to me that the "guru" gets the prize.
after all, assuming all is fixed, he's the one who got you back to where you should be......
no more model As for now........
Chris in WNC is offline   Reply With Quote
Old 03-15-2013, 12:31 AM   #14
Michael in Sedona
Michael in Sedona's Avatar
I think that we all won the prize by following your mystery and then finding out what the problem was. This may help any one of us who has a similar problem in the future. Thanks!
Michael in Sedona is offline   Reply With Quote
Old 03-15-2013, 04:05 PM   #15
Tom Wesenberg
Tom Wesenberg's Avatar
I wouldn't be resting easy just yet.
So many different things were tried, and poor connections can come and go, but wouldn't your battery ground having a poor connection have shown itself as slow to crank or no crank at times? Since the starter draws 100+ amps, it takes the best connections to make sure it cranks normally, and I don't recall slow to crank ever being mentioned.
Old 03-15-2013, 04:47 PM   #16
Mitch//pa
the brief sputtering that was reported on the road test ,(crap in the fuel) has been playing in my mind. i hope it is fixed and the sputtering was nothing but it has me worried.
Old 03-15-2013, 05:47 PM   #17
sgwilson904
Don't dare to speak it, Mitch, but I worry about that myself. Guru has already suggested getting carb completely rebuilt and he will have one handy on upcoming weekend day trip, just in case. My worry is that when we suspected the carb and replaced it earlier with one known to be good from another running car, the problem was NOT resolved, i.e. the working carb didn't solve sputtering/backfires, making us think fuel flow and carb were NOT the cause.
So, now that you're thinking along these lines, what are you thinking it MIGHT be that's still not fixed? What could be left?
Old 03-15-2013, 05:52 PM   #18
Mitch//pa
I feel Tom w made a good point. Is it cranking better than before since the high resistance was corrected
Old 03-15-2013, 10:41 PM   #19
BILL WILLIAMSON
After 13 pages, If Vermin died & I couldn't make him go, I'd be almost afraid to ask for help! My "brain" couldn't absorb/store all 13 pages of ideas! Bill W.
Old 03-15-2013, 10:51 PM   #20
Fred K-OR
Fred K-OR's Avatar
I also go along with Tom's idea. I think there is some other problem and my $.02 worth of comments would be that it is something electrical. But what is confusing about it being electrical is that an electrical problem would normally close the engine down, not let it sputter. So I am not of much help here except I don't think you have found the problem yet!
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
