Old 03-13-2013, 04:56 PM   #1
VWJoe
VWJoe's Avatar
Default Cleaning Zinc running board trim
After reading many, many posts on claening Zinc (i.e. using lemons, rubbing on tomato paste, using vinager, etc, etc.) I tried using some aluminum cleaner I had on hand. It worked great. I brushed on the jelly-like cleaner, let it set for 5 minutes, then scrubbed it with a fine 3M scotch brite pad (red or gray). Very little scrubbing was needed. Then I removed the cleaner with a wet towel. It removed all the white and dark gray corrosion and left the Zinc a dull aluminum color. I then used some Blue Magic chrome polish to bring back the shine. Each running board took about 30 minutes to complete and turned out great.
VWJoe is offline   Reply With Quote
Old 03-13-2013, 05:07 PM   #2
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Default Re: Cleaning Zinc running board trim
You are right about that, it turned out great!
Old 03-13-2013, 07:17 PM   #3
59mgaguy
Lemon, tomato, and vinegar are all acids. What you did was remove the protecting zinc coating.
59mgaguy is offline   Reply With Quote
Old 03-13-2013, 07:59 PM   #4
wrndln
I thought runningboard trim was solid zinc, not a zinc coating. I think the whitish material that forms on the trim and looks bad was an oxide. I thought the chemicals just removed the oxide coating and not much or any underlying zinc.
Rusty Nelson
Old 03-13-2013, 08:09 PM   #5
Mike V. Florida
Rusty Nelson
Your right as is 59mgaguy. Zinc with create this coating to protect it's self, sort of line the green coating you get on copper.
Your cleaning removed the coating like polishing will remove the green coating of copper.
Old 03-13-2013, 10:33 PM   #6
Steve Plucker
Just courious...is the trim original or reproduction?
If repro...do we know if the repro is made of the same substance as the original?
Pluck
Old 03-14-2013, 01:00 PM   #7
VWJoe
VWJoe's Avatar
These were repo running boards that came with the car. They were stored uncovered in a barn since 1995. I think they came from Mac's as most all the other new parts the PO bought came from there. Whatever they're made of (zinc, zinc alloy, chinese steel, etc.) they sure look better than those nasty stains. A power buffer with rubbing compound wouldn't remove them. I'm happy!!!
Old 03-14-2013, 03:09 PM   #8
59mgaguy
Since you removed the zinc you'll find that the steel underneath will rust a lot faster. So you'll have to keep up with the polishing of the RB trim.
As for the green coating on copper it's oxidation not a protective coating. But I understand what you were trying to say.
Old 03-14-2013, 06:47 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Think I'll try Wright's Silver Cleaner, wonder if it would be "safe" for my nickle plated headlights?? I've never polished them yet. I'm afraid to try "Brasso"! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 03-14-2013, 07:48 PM   #10
Skibb
Skibb's Avatar
VWJoe, your garage floor is so clean I'm sure your Model A doesn't spend much time there.
Skibb is offline   Reply With Quote
Old 03-14-2013, 08:24 PM   #11
ct1932ford
ct1932ford's Avatar
Try Never-Dull used it since I was a kid.
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 03-14-2013, 09:19 PM   #12
BILL WILLIAMSON
I had forgotten about Never-Dull, Ct, gets smelly when old, but still works well! HMM! sounds like a definition of ME! It originated with the Navy for shining brass & most anything. Would it help my head?? Bill W.
Old 03-08-2018, 06:44 PM   #13
oldforder
oldforder's Avatar
Bill, I just did my nickle headlights on my 29 2 days ago with brass, and it worked well.
Oh darn, I just realized that I was looking at a 4 year old post.
oldforder is offline   Reply With Quote
Old 03-08-2018, 08:34 PM   #14
duke36
Timely question as we just did ours with Mothers Mag Wheel polish in one step. Wonderful product that even shines up plastic head light lenses and other elements as it's not too abrasive. Most local parts stores should have it.
duke36 is offline   Reply With Quote
Old 03-08-2018, 09:15 PM   #15
jimalabam
jimalabam's Avatar
"bout" that Duke quote : Really is "A man has to do what he has to do" ...
jimalabam is offline   Reply With Quote
Old 03-08-2018, 11:55 PM   #16
PalAl
PalAl's Avatar
That did turn out nice! I am in the process of doing the same job, I'm using FLITZ Metal Polish with 0000 steel wool to start and ending with just the polish. Looking almost as good as new. Have had a quart can of this stuff for almost 15 years, got it at Oshkosh WI Air show. Also got the blue buffer that you put on your drill motor.
http://www.flitz.com/
PalAl is offline   Reply With Quote
Old 03-09-2018, 09:05 AM   #17
Cool Hand Lurker
Cool Hand Lurker's Avatar
After cleaning, give it a spray-can coat of clear lacquer to keep the oxidizing from coming back.
Cool Hand Lurker is offline   Reply With Quote
Old 03-09-2018, 03:07 PM   #18
BILL WILLIAMSON
I've "heard" to clean headlight reflectors, just use a DAMP CHAMOIS???
Bill Shine
