Old 03-13-2013, 10:30 AM   #1
gkgeiger
gkgeiger's Avatar
Default Anyone running a 3.25 ratio rear?
I will be installing my rebuilt 276ci FH in a couple weeks and was wondering if anyone is running a 3.25 rear with a 39 trans. I'd really like to be able to keep up with my buddies and their OD equipped cars. I currently have a 3.78 w/7.00X16 rear tires.
Gene
gkgeiger is offline   Reply With Quote
Old 03-13-2013, 10:51 AM   #2
David J
David J's Avatar
Default Re: Anyone running a 3.25 ratio rear?
May work better for you with a bigger motor . With a stock 34 it is kinda poochy . The 67- input and cluster help with takeoff but you find yourself shifting more to make up for the wider gaps in the tranny ratios . Yes this isn't exactly what you asked but it is an example of 3.25 gears in a stock 34 . Won't do it again . 3.54'S!!!!!!!!!!!!!!!! Something that helps also is a pair of tall rear tires for extended trips . Easiest way to change rear gear anyway .
David J is offline   Reply With Quote
Old 03-13-2013, 12:20 PM   #3
Chris Nelson
Chris Nelson's Avatar
I have used 3.25:1 ratio in two cars with great success.. I also have used a C-4 automatic in that application. One is a 36 Ford Conv and the other is a 46 Ford conv.. The engine was a .080 over bore in both cases. Of course you aren't going to tear up tires at the stop light, but who wants to ruin good tires anyway.
Chris Nelson is offline   Reply With Quote
Old 03-13-2013, 12:49 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
It depends mainly on the weight and hp of the vehicle. A friend put 3.25 gears (replacing 4.11) in a light weight Track T roaster running a basically stock 8ba engine. This put his engine RPM right where he wanted it to be at 55 mph.
John
Old 03-13-2013, 06:17 PM   #5
alan
go with a 3:54, I currently have a 3:25 with a 51 Merc engine/77b isky cam in my 41 truck same 3 spd as yours and it is hard to get going on about any stoplight on a hill, have to slip the clutch, I am going back to the 3:54 but 3:25 will really make it run down the road!!!
alan is offline   Reply With Quote
Old 03-13-2013, 08:17 PM   #6
PeteVS
PeteVS's Avatar
"67" gears... Is this the pickup trans with 29 tooth cluster?
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 03-13-2013, 09:36 PM   #7
alan
28 tooth car trans, there are actually two 29 tooth first gear cluster gears, pick-up and bus which is even lower-I have a set of those gears and first goes about ten feet , second goes about 20 more feet and then you are dead in the water for acceleration-but would pull a dead horses thru a key hole
Old 03-14-2013, 08:44 AM   #8
flat-v8
flat-v8's Avatar
Pull a dead horse thru a key hole! Haaaa Haaaa! LMAO that is funny!
flat-v8 is offline   Reply With Quote
Old 03-14-2013, 06:08 PM   #9
David J
David J's Avatar
Yessir - and it is a combination I won't be using again . See Alans post . Pretty well sums it up . New computer and me & it ain't getting on well yet !!!!!!
Old 03-14-2013, 07:17 PM   #10
Kube
Kube's Avatar
I own eleven horses. Buried a number through the years. Let me tell ya first hand, ain't no old flathead Ford gonna pull a horse through a key hole.
Old 03-14-2013, 07:45 PM   #11
Butch11443
Butch11443's Avatar
Got 3:26's behind a 239 in a 31 Pickup. Using a 29 tooth cluster in a 37 case. It works out real good for me.
Butch
Butch11443 is offline   Reply With Quote
Old 03-14-2013, 07:51 PM   #12
farmer dave
i have 3.25 in 46 convertible stock 8 ba runs great no problems with hills lots of model A'S running 327 in stock engins that work well here
farmer dave is offline   Reply With Quote
Old 03-14-2013, 08:02 PM   #13
havi
havi's Avatar
Had a 3.25:1 9" rear in a '74 F100 w/3sp and 302..... it hauled pretty good! the 9" has some parasitic HP loss, but a built flatty like yours should be no problem to overcome that. However, the jumps in the 39 tranny gears may make a 3.54 better. crashbox 4sp w/3.25's is decent. A T5 w/ 3.54's is dang good. So, doing the mental math, I'd say 3.25's would be ok, except maybe on really big hills.
I'm just an old truck guy trapped in a hotrodder's world.
havi is offline   Reply With Quote
Old 03-14-2013, 09:04 PM   #14
Ol' Ron
Ol' Ron's Avatar
I have several friends running 276 engines L-100 cams in heavy cars. these cars have 3.78 rear gears. However, they also have a Michael OD unit. now this puts the final drive into the mid 2.5/ 2.8 and yet they can drive very comfortably around in hi range. so I don't think a 3.27 would bother a well built engine, and give great economy.
Old 03-15-2013, 07:09 AM   #15
gkgeiger
gkgeiger's Avatar
Thanks for all the responses. I think I'll give it a try. i really would like a Mitchell but this would be much cheaper.
Gene
Old 03-15-2013, 07:35 AM   #16
skidmarks
skidmarks's Avatar
I had one with a 8BA and a s10 5 speed. Worked fine but 1st gear in the s10 trans is 4 to 1 and taking off in second needed to slip the clutch alittle. 5th was great with the 325 rear. Can't say with a 39 box.
skidmarks is offline   Reply With Quote
