Old 03-11-2013, 06:43 PM   #1
5window
5window's Avatar
Question What are these odd interior blocks?
These interior blocks, some sort of composite?, appear to be original to the car ('31 coupe) and are shaped to blend the complex curve of the door post into the flat surface below the window to mount the interior to. In the first picture, the middle piece is actually pointing at the camera and shows the broad side profile. The second photo shows where they mount, with two wood screws, against the door post. Mine need to be replaced. Any ideas of what they are called and who might sell replacements? Thanks
5window is offline   Reply With Quote
Old 03-11-2013, 06:55 PM   #2
fivefix
fivefix's Avatar
Default Re: What are these odd interior blocks?
Page A-185, bottom left corner, of Snyder's 2012 catalog....
"Latch Wood - This part originally was made of hard rubber. It mounted vertically about half way up the door post. Used on 1928 - 31 Coupe, Tudor and 1930 - 31 Pickup. Included in body wood kits. U.S.A."
They're now made from wood and Snyder's sells them for $19.50 per pair. I'm not sure if rubber reproductions are available or who has them.
fivefix is offline   Reply With Quote
Old 03-11-2013, 07:30 PM   #3
5window
5window's Avatar
Thanks. That's what I was looking for. Although, maybe at $19.50 plus shipping, I'll try to make my own.
Old 03-11-2013, 07:55 PM   #4
TinCup
TinCup's Avatar
I searched for the bakelite versions of these but never found them. I ended up getting a set from Snyders.
TinCup is offline   Reply With Quote
Old 03-12-2013, 06:17 AM   #5
Steve-Greensboro
I think these are not door latch cover blocks, but are wedge shaped block that attaches to small block shown on lower side of quarter window. You can see the two wood screw holes on that block in your picture. If that is what they are, the should be one half to three quarters thick at one end and about one eighth inch thick at other end.
Steve-Greensboro is offline   Reply With Quote
Old 03-12-2013, 08:20 AM   #6
Farrell In Vancouver
Farrell In Vancouver's Avatar
I think Steve is right, they looks like an upohlstery bolster to make the transition from the B-pillar to the wall under the 1/4 window. Could easily be made of wood.
Farrell In Vancouver is offline   Reply With Quote
Old 03-12-2013, 09:37 AM   #7
5window
5window's Avatar
Yes, these are some sort of composite or very dried rubber that taper to almost a point as transition filler. It looks like I'll be firing up the wood tools.
Old 03-12-2013, 10:17 AM   #8
TinCup
TinCup's Avatar
Here is a shot from when I re-upholstered the coupe.
Old 03-12-2013, 05:08 PM   #9
5window
5window's Avatar
Thanks for the photo. Here's what I ended up with-pretty close-close enough.
