04-16-2023, 10:42 AM | #1 |
fuel pump push rod
I was thinking about drilling and tapping a hole on top of my fuel pump push rod for an adjustment screw that will make contact with my fuel pump as it no longer does since my stock 41 flathead has been rebuilt. The pushrod is the correct 8.87" for 35-48 Fords. It appears my cam lobe had been reworked during rebuild.Any words of advice or cautions will help as I cannot pull fuel to mypump otherwise.
04-16-2023, 10:50 AM | #2 |
Re: fuel pump push rod
I seriously doubt that the pump lobe would be ground. Do you have a glass bowl on your pump? If so, I would suspect the gasket is not sealing the bowl properly.
04-16-2023, 11:11 AM | #3 |
Does the pushrod move up and down when cranking the engine? Somewhere in my stash I have a small container that has caps for pushrods to slightly lengthen them.
04-16-2023, 11:28 AM | #4 |
If you've changed the intake manifold to one with a taller pump mounting surface this can happen. Also, if the rod isn't moving, check to see if the rear cam bearing is partly covering the edge of the bore the pushrod sits in. Lots of times the rear bearing is driven in too far and this occurs. Of course the pushrod still contacts the pump arm, just doesn't move.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
04-16-2023, 02:40 PM | #5 |
i've tried 2 different fuel pumps (rebuilt), one with glass bowl sealed good, one original style w/ no glass bowl. I,ve tried leather spacers too with no suction. i have original intake, new block same type. I'm going to try a new fuel pump and new push rod because I'm getting no action when i hook the fuel hose up to either pump and cycle them by hand. I appreciate comments.
04-16-2023, 02:43 PM | #6 | |
Have you cranked the engine with the fuel pump removed and the rod installed to see if it moves?
04-16-2023, 05:02 PM | #7 |
I forget the specific number, but I think the stroke of the pushrod is supposed to be about 0.20". That should be easy to see and you could confirm it with a dial indicator.
04-16-2023, 06:36 PM | #8 |
Check out were they likely had a Electric Fuel back at the tank ,I have one were working on by the look of the joint and clamps this one would be a non starter ( a leak stain ) ,suckin air ,your flex hose at the pump can be porous to , Ted
04-17-2023, 02:54 AM | #9 |
Check how far the push rod moves up while turning the engine over slowly. Should be 1/10" of an inch. Some new fuel pumps non genuine have far too much movement in the actuating arm and dont pump anything. Regards, Kevin.
04-18-2023, 06:28 PM | #10 |
thanks to all. I will post my results after yet another fuel pump rebuild and a new push rod as mine shows indication of wear.
04-18-2023, 08:59 PM | #11 |
04-19-2023, 06:06 AM | #12 |
04-19-2023, 08:31 AM | #13 |
He said he did in Post #5.
https://www.nirgv8.org |
04-28-2023, 08:04 AM | #14 |
leveled off the car as i was defying gravity before. removed the spark plugs to get a stronger spin, and demonstrated patience before the fuel bowl filled. ok now. thanx to all!
04-28-2023, 04:08 PM | #15 | |
https://www.jalopyjournal.com/forum/...131795/page-18 |
04-30-2023, 10:14 PM | #16 |
To lengthen a push rod you could take an empty casing from a 38 caliber cartridge, grind the base where the primer is located to the amount of lift you want, and drop it on the rod.
Oh, be sure to use a fired cartridge, not a new one! |
04-30-2023, 11:20 PM | #17 |
Be sure to avoid the pump with a slotted bush that drives the arm .
05-01-2023, 06:15 PM | #18 |
05-02-2023, 05:41 PM | #19 |
There's a pump out there that has a slot were the tradinial pump just has a bush ,and is hinged ,this other type has a full length arm ,I can see how it works the arm jiggles up and down or when the diaphragms up it disengages the action ,5psi to .
05-02-2023, 06:32 PM | #20 |
Not that this will effect you right now, since you have discovered your immediate problem, but I have a '55 Ford Courier sedan delivery that I often let sit all winter long in the garage. In the spring, I have to move it out to get the roto-tiller out but when I go to start the car, I have found that the fuel supply line to the pump has cavitated (either by evaporation or fuel flowing back into the gas tank). Every year I have to disconnect the flex fuel hose to the supply side of the pump and get a small funnel to re-fill the fuel line with gas. Once that is done, you can start anytime and drive anywhere, until next time I leave it setting abandoned for six months. Maybe it just gets lonely sitting out there.
