Old 03-18-2018, 12:37 AM   #1
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
Default Diaphragm Clutch
On lightened flywheels and V8 Clutch conversions, diaphragm pressure plates and clutch discs are becoming popular.
I would like to know what vehicle the clutch comes out of and the comparative advantages and disadvantages of this setup over the more conventional "long clutch" from early Ford V8
Thanks
Richard
Anaheim CA
Richard in Anaheim CA is offline   Reply With Quote
Old 03-18-2018, 07:39 AM   #2
James Rogers
James Rogers's Avatar
Default Re: Diaphragm Clutch
Richard, I believe the early 60's Chevy 6 cylinder cars with a 9" disk.
James Rogers is offline   Reply With Quote
Old 03-18-2018, 11:12 AM   #3
Ron in Quincy
Ron in Quincy's Avatar
Richard,
If you decide to use the diaphragm clutch, the fingers at the center must be machine shortened, otherwise they will not clear the throw out bearing. You can use the same clutch disc as used with the V8 and A . Also, the flywheel must be drilled and tapped for the diaphragm or V8 pressure plate. Also the diaphragm clutch is much lower profile than the V8.
I am sure you know the above information but thought it would not hurt to list again.
Here in Quincy we are lucky that one of our members has a nice complete shop set up at he residence and does any machine work we may need.
Ron
Ron in Quincy is offline   Reply With Quote
Old 03-18-2018, 11:38 AM   #4
john in illinois
john in illinois's Avatar
Richard, Here is a substitute clutch plate for the Ford Long V8 plate.
You do not have to enlarge the center arms and theybhave the correct angle for the Ford throw out bearing and hub. There is a 10 and 11”. The 10” is the one.
https://www.rockauto.com/en/catalog/...ure+plate,1988
Ford Barn V8 discussion. https://fordbarn.com/forum/showthread.php?t=159786
John
john in illinois is offline   Reply With Quote
Old 03-18-2018, 12:10 PM   #5
Jim Brierley
Clutch Masters in Rialto, I've heard, stocks a lightened wheel and diaphragm clutch. I believe it uses a Ford Ranger pickup clutch cover.
Old 03-18-2018, 02:57 PM   #6
wensum
wensum's Avatar
I have a diaphragm clutch in my car, unfortunately I don't know what it's off as the clutch man who happened to own a Model A said this will do and also provided a modern throw-out bearing to suit which fitted the Model A. All very simple and a nice light & smooth clutch
wensum is offline   Reply With Quote
Old 03-18-2018, 06:39 PM   #7
Thanks guys.
I can always depend on Fordbarn when my brain takes a vacation
Old 03-18-2018, 10:36 PM   #8
CarlG
CarlG's Avatar
I have a diaphragm clutch plate in my pickup. It came with the lightened flywheel I bought from Ron Kelley.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-19-2018, 12:44 AM   #9
hardtimes
hardtimes's Avatar
Originally Posted by Richard in Anaheim CA View Post
Thanks guys.
Hey Richard,
I have installed a new diaphragm pressure plate on my new B rebuild. It is 9", and I got the model / part # from CarlG here. As Carl says, his came on his engine from the rebuilder. I think that I have the part # somewhere, if you think that that would be of any help, I'll look for it ?
I've been using the B on a stand as a test mule. The parts (pressure plate/disc and flywheel) was balanced out as a unit. It runs out very smooth !
BTW...I don't know anything about the comment that you must do some mod to the clutch fingers. I have tried a new throw out bearing on the model pressure plate that I used and I can't see a problem.
Old 03-19-2018, 07:56 AM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The only shortcoming of that clutch is, when the Diaphragm decides to crack, it slips INSTANTLY!!! And "hopefully" COASTS HOME!
Bill Veryoldclutchrebuilder
"THE ASSISTANT GURU OF STUFF"
Old 03-19-2018, 08:13 AM   #11
Hoop
Hoop's Avatar
"BTW...I don't know anything about the comment that you must do some mod to the clutch fingers."
The fingers on the pp "grow" inward as the clutch is depressed. Note the groove cut. There's no apparent interference ... until the cutch is depressed ... then clutch pedal hangs up. Any need for modification would depend on the pp selected.
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 03-19-2018, 08:27 AM   #12
western77
western77's Avatar
A 9 inch pressure plate from a early ford ranger will work. Just needs new mounting holes.
western77 is offline   Reply With Quote
Old 03-19-2018, 08:59 AM   #13
katy
katy's Avatar
That sounds odd compared to my experience, I had a diaphragm clutch in a 1980 F-150 that cracked and then wouldn't release.
Old 03-19-2018, 02:07 PM   #14
hardtimes
hardtimes's Avatar
Attachment 354665
Hey Hoop,
I see what you're saying.
I think that's why the pp that I have on the spare engine is working, as it was researched by an engine builder and found to not have to be altered. Thanks for the picture, it looks different from my pp.
Also, I've often heard some say that you need to use a 'special' throw-out bearing when using diaphragm pp. Again, my new bearing fits pp very well. My guess is that the 'fingers' , is shaped differently , may require a different bearing ? But, how to know what bearing ??
Old 03-19-2018, 03:14 PM   #15
bettlesr
bettlesr's Avatar
When I changed my Corvette from 3 finger to diaphragm type the throwout bearing had to be changed from flat faced to curved face as the multiy fingers of the diaphragm clutch change angle as the bearing is pressed in to it.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 03-19-2018, 03:45 PM   #16
CarlG
CarlG's Avatar
Originally Posted by hardtimes View Post
Hey Richard,
I have installed a new diaphragm pressure plate on my new B rebuild. It is 9", and I got the model / part # from CarlG here. As Carl says, his came on his engine from the rebuilder. I think that I have the part # somewhere, if you think that that would be of any help, I'll look for it ? ...
Picture in post #8 Hover over picture for part # (Sachs BBC1904)
Alaskan A's
Old 03-20-2018, 01:57 AM   #17
hardtimes
hardtimes's Avatar
Hey Carl,
Thanks much for that post and information. Yeah, I took your advice/info and have that setup on my new B.
BTW..
hovered of picture just as you advise..nothing.
Wonder if it is just me/my machine here or what.
A short time ago (month or so) something happened. I also can't now put up the little smiley faces, can't post pictures as used to and now can't 'hover'..(smiley face here!).
Always a silver lining, if looked for though. For years, till now, when I looked at several pictures posted by anyone, I had to look at one at a time and go back an then another so forth. NOW, all of a sudden it is back like in the old days...i.e.-, I can now view first picture then just click on 'next' and voila..whoohoo ! What the heck, I'll settle for that. Past bedtime and most likely not making sense.
Old 03-20-2018, 11:22 AM   #18
Jim Brierley
If you use the original flat-faced bearing, it will work but will likely give a funny feel to the clutch and not release as smoothly. The first diaphragm clutch I installed was from a high performance Mustang and the fingers rubbed on the front bearing retainer, at the very front. I merely ground a little off the internal finger diameter and all was well. The second one, from a Ranger pickup was fine as-is.
Old 03-20-2018, 02:02 PM   #19
CarlG
CarlG's Avatar
Hey Carl,
BTW..
When I first posted that picture, the "hover" worked. 5 minutes later it didn't, so that is why I went back and posted the part number. Go figure!
Alaskan A's
Old 03-20-2018, 03:39 PM   #20
hardtimes
hardtimes's Avatar
THANKS for that (tooth grin face) !
This time it ain't me and my computer.
