Old 09-20-2024, 08:28 AM   #101
sjaakslinger
sjaakslinger's Avatar
Default Re: '36 221 - rebuildable??
More progress!
Verstuurd vanaf mijn SM-G781B met Tapatalk
sjaakslinger is offline   Reply With Quote
Old 09-21-2024, 06:04 AM   #102
38 coupe
38 coupe's Avatar
Nice!
Old 09-21-2024, 12:31 PM   #103
Bored&Stroked
Bored&Stroked's Avatar
Great progress! You're really doing this engine as it should be done - congrats on that.
Note: It looks like you have the incorrect bolts for the cam timing gear. You want to use the original "shoulder bolts". If the bolts you have do not have the correct shoulder on them (non-threaded), then there is a chance the cam-gear can move.
Pull one of them out and post a picture - then I can tell you for sure if it is an issue or not. The original style bolts are available new from Third-Gen . . . or there are lots of them lying around as they used the same style for many years.
Old 09-21-2024, 12:33 PM   #104
Bored&Stroked
Top-End: Hopefully you're putting the later 49-53 style valves and guides in the engine. The later setup is much better than the original "split guides" and mushroom stem valves that came in the engine.
Old 09-21-2024, 05:55 PM   #105
jers36
jers36's Avatar
I was reading your article about the different numbers on your engines heads. I have a 36 PU and it has the same numbers 68-6049B and 68-6050B. I have seen other 36's with the same numbering but I don't know why. What really got my attention was when you were trying to define if it has insert or babbit bearings. I think my engine is original to the truck but of course I have no way of knowing for sure. My engine has large block off plates where on newer engines the water pumps mount on the front of the block. Is this a definite sign that you would have a LB engine?
jers36 is offline   Reply With Quote
Old 09-22-2024, 01:02 AM   #106
sjaakslinger
Yep, later style!
About the cam gear bolts. I'd have to check with the rebuilder. I did buy the set (bolts and that 'securing plate') from 3rd GEN, so it should be the correct ones.
Old 09-22-2024, 01:06 AM   #107
sjaakslinger
Those 68- prefix heads are later (not factory) installed heads as far as I've understood. Those block off plates in the front mean your engine block itself is '37 or later. For the original '36 look, they put on those plates and used the '36 heads.
So after 1936 all the engines had the insert bearings.
Old 09-22-2024, 11:21 AM   #108
jers36
jers36's Avatar
Thanks for the info, you just really made my day! The thought that I may have babbit bearings has always been a dark cloud over my head. I admire your determination to learn and rebuild your engine. You are doing a great job.
Old 09-22-2024, 12:14 PM   #109
GB SISSON
GB SISSON's Avatar
I your photo of the new aluminum cam gear it looks like perhaps you are running it with a used crank gear. This is what I did and am not too happy with the noise created by the combination. It was a very loud whirring noise at initial start up that lasted about ten minutes and I was much happier when as became a higher pitched whine. I was told on this forum that it comes from a worn steel crank gear slowly imprinting it's wear into the softer cam gear. I was told that the two gears will slowly 'find each other', but may be at around 6000 miles before it's truly quiet. At this point at maybe 2000 miles, it's the only part of my build I would have done differently. I have been tempted to research if there is an alternative fiber type gear that is neither a 75 yr old ford product or an inferior new 'overseas?' gear. If I'm correct about your new and old gears I would suggest addressing this while it's easily accessable.
Old 09-22-2024, 12:50 PM   #110
tubman
tubman's Avatar
Some people pay extra to purchase "Noisy Timing Sets" for SBC's.
Old 09-22-2024, 01:35 PM   #111
Bored&Stroked
Nothing like the ole' Milodon or Pete Jackson gear drives! Sounds sort of like some blower whine . . . but not nearly as cool!
Sounds pretty good on a Hilborn injected SBC!
Old 09-22-2024, 06:52 PM   #112
GB SISSON
GB SISSON's Avatar
So, you two are saying my whirring noise is cool? Then I guess I'll just drive around enjoying being a hot rodder! That was an easy fix...
Old 09-22-2024, 10:30 PM   #113
sjaakslinger
Ah, good question, I'll ask the rebuilder. I did provide them with a new crank gear...
Old 09-22-2024, 11:28 PM   #114
deuce lover
deuce lover's Avatar
That information about the noise buy using an alu Cam gear was told to me by an old time flathead engine builder when I was rebuilding the 36 LB for my 33. I sourced a NOS fiber gear and used it instead. No noise. My engine had the cam with the press on gear.
deuce lover is offline   Reply With Quote
Old 10-19-2024, 03:03 AM   #115
sjaakslinger
Getting there!
This is probably going to be the best (read most expensive) engine in a patina'd looking 4 door Sedan that's around, but ok... In hindsight we might have better sourced a good running one, but well...no way back now. I saved some money by sourcing all the parts myself and dragging them home from the US.
The car will have a restored chassis, engine, brakes and electric. That we'll all do ourselves. The body will keep it's original look. Who knows, maybe some day we'll do a 5w or 3w body swap.[emoji16]
Dennis
Old 10-25-2024, 12:21 AM   #116
sjaakslinger
Painted.
Old 10-25-2024, 04:24 AM   #117
fortyonerag
fortyonerag's Avatar
Great thread, many thanks. I rebuilt a flatty recently. As a friend told me, "It costs a lot of money to go slow these days"
Loving your work!
fortyonerag is offline   Reply With Quote
Old 10-26-2024, 10:51 AM   #118
Bored&Stroked
You will be like a little kid at Christmas time when you first fire it up! You've done a great job in rebuilding this engine and not taking short-cuts that you'll regret later on.
Thanks for all the posts!
Old 10-26-2024, 11:15 AM   #119
sjaakslinger
Thanks. The engine looks like a piece of art. Indeed I can't wait to fire it up! That'll have to wait a little while unfortunately. The rebuilder needs the space, so we will move it soon. When the chassis is on it's wheels we will put the engine and trans in. Then it's time for it's first start.
Can't wait to put it on the chassis and put on the generator, carb, starter, etc.
The color is RAL6012 by the way. I think that worked out very well.
Dennis
Old 10-26-2024, 11:25 AM   #120
tubman
tubman's Avatar
That's a lot of green. In more ways than one.
Congratulations on your project. I like "first starts" so much, I built an engine test stand.
