#1 |
A very simple solution would be develop an app for your smart phone to remind you to rotate your crank every month or for you younger married guys use your wife's monthly cycle as a reminder. Problem solved!
#2 |
Once a month would be the absolute minimum. Since the young guys have more energy and stamina, perhaps they should rotate their crank more frequently.
#3 |
This Thread has been like a bad accident on the interstate / while you really don't want to look at it by the time you get up to it you JUST HAVE TO LOOK. " LOL "
#4 |
Bill, I think you're right. But instead of slowing down to look at the accident, try speeding up. Einstein observed that light and objects appear to bend at great speed, so if you speed by any crankshaft lying on a floor and blink fast enough it will appear bent. Einsteins theory of...
#5 |
Six pages of opinion , but no facts. Do they bind or do we just think they bind. How much ?? If in doubt ,just stand them on end and be done..
[QUO[/QUOTE]no matter where you are,or where you're at, there you are...
#6 |
#7 |
dude, If you stand them on end, almost all the weight is pushing down on that last crank throw, right? And there's no support at the centerline of the crank, right? So eventually the crank will bend and maybe topple over, even! Whereas, if the crank is lying on the floor it is being supported at least in three or four places, thus spreading the weight out instead of all being focused at one point if it were standing on end!
#8 |
'Resistance is futile' , In '95 Western Oregon had a 5.6 earthquake and I could hear my merc cranks falling over in the shop! Ring, ding, and clank! The one that has since been checked was badly cracked. Later Newc
#9 |
See what can happen? Molly would have laid 'em all flat. Every last one of 'em.
#10 |
Hey rheltzel, does she still live in sac? What a gal! Wouldn't mind seein her again.......I'm not far away......sigh....laid my crank flat many a time.....sigh....
Alive n kickin n mostly kickin! |
#11 |
Sadly, she is not in Sacramento. After years of working in the Rouge Plant cafeteria and suffering through too many harsh Dearborn winters, Molly moved to Florida and opened a profitable crank straightening business there for those whose cranks were bent from being laid and who were in need of re-straightening. It is said that Molly could straighten old bent cranks when no one else could. She was, as you can imagine, a legend in her time.
#12 |
lolololo...to bad...sigh...lololo
#13 |
Ok, I'm done now.......no more on this thread....my sides hurt!!
#14 |
It has been verified that a sheet of window glass standing vertically will eventually become thicker at the bottom than at the top. It sort of slides down as if like honey. I suppose this could happen to a vertically standing crank if left that way for a long period of time. So make sure when storing you alternate positions from time to time. Need data to know the proper timing on this theory. Has anybody on the BARN done the research ?
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS..... http://s818.photobucket.com/home/roglehr/index |
#15 | |
'52 F-1, EAB flathead |
#16 |
Also...if this IS a problem...what is the time frame? How long between laying down a crank and measurable bending? If the time is relatively short...
lay 3 carnks into a spare block, rotate'em against an indicator. If straight. leave one in the block, lay one flat, stand one on end. Re-indicate at given time... The belief in bending seems to come largely from machine shops, where i would assume cranks don't hang around long before going to a home. In our cases, I'm sure some of us have cranks that have been in one place for multiple decades. Science needs to know... |
#17 |
Okay, I've solved the problem....Grease, we fill a pool with heavy grease and lay the crank in the grease and as the crank slowly sinks to the bottom over the years ,the grease evenly supports the crank from all sides and prevents rust. Problem solved.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
#18 |
Nothing new there. That's how Molly would start her day off with a bang.
Alan |
#19 |
Fibber you best make sure it is corn head grease. Molly probably used it also. Corn head that is.
#20 |
There was a company in South Gate called Chrome Crankshaft that polished cranks and you could get your bumpsticks done as well.
Bruce
Works good Lasts long time |
