Old 06-06-2015, 06:23 PM   #101
Fe26
Default Re: Gravity bends a crank?
Bill, I think you're right. But instead of slowing down to look at the accident, try speeding up. Einstein observed that light and objects appear to bend at great speed, so if you speed by any crankshaft lying on a floor and blink fast enough it will appear bent. Einsteins theory of...
Fe26 is offline   Reply With Quote
Old 06-07-2015, 10:45 AM   #102
dude
dude's Avatar
Six pages of opinion , but no facts. Do they bind or do we just think they bind. How much ?? If in doubt ,just stand them on end and be done..
[QUO[/QUOTE]no matter where you are,or where you're at, there you are...
dude is offline   Reply With Quote
Old 06-07-2015, 12:16 PM   #103
rheltzel
rheltzel's Avatar
I beg to differ. Everything said about Molly Cules was absolutely factual and true.
rheltzel is offline   Reply With Quote
Old 06-07-2015, 12:19 PM   #104
40 Deluxe
dude, If you stand them on end, almost all the weight is pushing down on that last crank throw, right? And there's no support at the centerline of the crank, right? So eventually the crank will bend and maybe topple over, even! Whereas, if the crank is lying on the floor it is being supported at least in three or four places, thus spreading the weight out instead of all being focused at one point if it were standing on end!
Old 06-08-2015, 10:47 AM   #105
Newc
Newc's Avatar
'Resistance is futile' , In '95 Western Oregon had a 5.6 earthquake and I could hear my merc cranks falling over in the shop! Ring, ding, and clank! The one that has since been checked was badly cracked. Later Newc
Old 06-08-2015, 11:41 AM   #106
rheltzel
rheltzel's Avatar
See what can happen? Molly would have laid 'em all flat. Every last one of 'em.
Old 06-08-2015, 12:18 PM   #107
rowens55
rowens55's Avatar
Hey rheltzel, does she still live in sac? What a gal! Wouldn't mind seein her again.......I'm not far away......sigh....laid my crank flat many a time.....sigh....
Alive n kickin n mostly kickin!
rowens55 is offline   Reply With Quote
Old 06-08-2015, 12:22 PM   #108
itslow
itslow's Avatar
Originally Posted by Lincoln View Post
My previous employer, who manufactured medium-to-large industrial stationary type engines (up to 30,000 horsepower), had a policy to always store their crankshafts vertically as lying them down would "permanently" distort the throws even with the main bearing surfaces supported properly. So they were stored vertically with the flange end supporting it...
How were the counterweights and journals supported when stored in the vertical orientation?
Without additional support the counterweights and journals will still have a bending moment imparted upon them when stored vertically. This would have a cumulative effect as you move down the crankshaft towards the ground (assuming they were stored sitting on a surface instead of hanging).
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is online now   Reply With Quote
Old 06-08-2015, 12:30 PM   #109
Bruce Lancaster
Also...if this IS a problem...what is the time frame? How long between laying down a crank and measurable bending? If the time is relatively short...
lay 3 carnks into a spare block, rotate'em against an indicator. If straight. leave one in the block, lay one flat, stand one on end. Re-indicate at given time...
The belief in bending seems to come largely from machine shops, where i would assume cranks don't hang around long before going to a home. In our cases, I'm sure some of us have cranks that have been in one place for multiple decades.
Science needs to know...
Old 06-08-2015, 01:07 PM   #110
rheltzel
rheltzel's Avatar
Sadly, she is not in Sacramento. After years of working in the Rouge Plant cafeteria and suffering through too many harsh Dearborn winters, Molly moved to Florida and opened a profitable crank straightening business there for those whose cranks were bent from being laid and who were in need of re-straightening. It is said that Molly could straighten old bent cranks when no one else could. She was, as you can imagine, a legend in her time.
Old 06-08-2015, 01:11 PM   #111
rowens55
rowens55's Avatar
lolololo...to bad...sigh...lololo
Old 06-08-2015, 01:12 PM   #112
rowens55
rowens55's Avatar
Ok, I'm done now.......no more on this thread....my sides hurt!!
Old 06-08-2015, 01:20 PM   #113
Roger/Sacramento
Roger/Sacramento's Avatar
It has been verified that a sheet of window glass standing vertically will eventually become thicker at the bottom than at the top. It sort of slides down as if like honey. I suppose this could happen to a vertically standing crank if left that way for a long period of time. So make sure when storing you alternate positions from time to time. Need data to know the proper timing on this theory. Has anybody on the BARN done the research ?
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 06-08-2015, 01:30 PM   #114
Fibber Mcgee
Fibber Mcgee's Avatar
Okay, I've solved the problem....Grease, we fill a pool with heavy grease and lay the crank in the grease and as the crank slowly sinks to the bottom over the years ,the grease evenly supports the crank from all sides and prevents rust. Problem solved.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 06-08-2015, 01:38 PM   #115
ford38v8
ford38v8's Avatar
Nothing new there. That's how Molly would start her day off with a bang.
Alan
Old 06-08-2015, 02:18 PM   #116
B-O-B
B-O-B's Avatar
Fibber you best make sure it is corn head grease. Molly probably used it also. Corn head that is.
B-O-B is offline   Reply With Quote
Old 06-08-2015, 02:38 PM   #117
cmbrucew
cmbrucew's Avatar
There was a company in South Gate called Chrome Crankshaft that polished cranks and you could get your bumpsticks done as well.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 06-08-2015, 02:59 PM   #118
Ross F-1
Ross F-1's Avatar
Roger, that was believed to be true for many years, until they found 600-yr-old glass that was thicker at the top. It turns out it was just a result of the process used to make it. If you can believe it, they used to blow glass in cylinders, cut it, and flatten it out.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-08-2015, 03:00 PM   #119
rheltzel
rheltzel's Avatar
Blowing glass is one thing. Crankshafts are an entirely different matter.
Old 06-08-2015, 03:52 PM   #120
scooder
Glass don't move, it stays the shape it was made. The belief was based on the thick bottom of a window. This was just the way it was put in in the first place.
And if JWL has stated that flathead cranks stored anyway for unknown time, show no evidence of "bending" in storage, when put on a crank grinder, then the question has been answered.
They don't bend.
Martin.
scooder is offline   Reply With Quote
