Old 04-17-2022, 08:31 PM   #81
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 1939’ Deluxe 2DR Sedan
Originally Posted by ssffnomad View Post
So I have done a ton of reading back in Fordbarn archives pertaining to U Joint Coupler . I now have JD Cornhead Grease.
My question is how much Grease to squeeze in ?
Squeeze-in at least this much or more....way more than you would ever think! You can't use too much. Throw your needles away and slop it on with your hand(s)! Definitely use the GREEN CORNHEAD Grease...not this red goop. Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 04-17-2022, 11:45 PM   #82
ssffnomad
ssffnomad's Avatar
Ok Sir . T/Y
Stretch
Hope everyone had a great Easter
ssffnomad is offline   Reply With Quote
Old 04-21-2022, 09:58 AM   #83
ssffnomad
ssffnomad's Avatar
Scored 3 Wide 5 rims & 2 drums . For spares. 3B9E3BDA-99AB-4520-ADF2-D26A66C143B0.jpg
Old 05-06-2022, 01:40 PM   #84
ssffnomad
ssffnomad's Avatar
Received new Firewall Pad from Quiet Rice.
The Dash, Hot Water Heater are currently out of it during new Wiring Harness project.
Some it was a good time.
Stretch
Old 05-30-2022, 10:37 PM   #85
ssffnomad
ssffnomad's Avatar
Not much time recently to get after getting the 39’ back on the road . But this morning was able to install the replacement Firewall Pad permanently. After many test fits.
Having a Ford 39’ hot water heater added a bit of work. Replacement Pad had knockout for hot exhaust heat , but none for hot water heat. Old Pad was so wore out, no way to get measurements off it.
New Pad being thick ABS there was no way to come from cowl towards dash with a Awl. But now it done. 3562977D-8A37-431C-9E01-75606797EFBF.jpg
Old 05-30-2022, 10:43 PM   #86
Tinker
Tinker's Avatar
Take it project to project. Looks like you are moving forward.
The old saying... how do you eat a train? bit for bite.
Every bit of work will get you forward. When your done, get ready to start over again. .
Good stuff dude.
Old 05-30-2022, 11:02 PM   #87
ssffnomad
ssffnomad's Avatar
Thanks Dude.
I would like to give “ Quite Ride Solutions “ a good shout. Only one I could resource a new 39’ Pass Car Firewall Pad from. Good phone conversations to confirm they could deliver said product. It took awhile, little short of their estimated delivery time.
Not cheap by any means. But the time to resource a new pad was now.
Stretch
Old 05-30-2022, 11:11 PM   #88
Tinker
Tinker's Avatar
One thing you understand is good things take time.
Old business saying. Fast, Cheap, Good. Pick two.
Glad things worked out. Its a patience hobby.
Old 05-30-2022, 11:35 PM   #89
ssffnomad
ssffnomad's Avatar
Yes Sir, and I am more than thankful for the information available here at the FordBarn.
Stretch
Old 05-30-2022, 11:38 PM   #90
Tinker
Tinker's Avatar
Lip stick on a pig calling me Sir. I'm just saying plenty of good info here. Not mine.
Look forward to more posts Stretch.
Old 06-03-2022, 05:07 PM   #91
ssffnomad
ssffnomad's Avatar
Ever go to put a new pot metal gear in the Windshield crank out mechanism, and get the gears out of wack ?
O Boy . . .
Old 06-05-2022, 10:09 AM   #92
ssffnomad
ssffnomad's Avatar
So I seems years ago someone reached under dash and globed a hand full of some type of grease on windshield gears. It was hard as a rock , so I took it apart to soak in parts cleaner.
Still fighting getting it correct. I have the arms in retracted position, evenly matched. Now attempting to get the Crank gear in proper position.
Any hints ?
Stretch
Old 06-11-2022, 06:26 PM   #93
ssffnomad
ssffnomad's Avatar
On a 39’ passenger car. Front of Master Cylinder adjustment rod. There is a pin with shoulder that brake pedal return spring attaches to. Spring must go forward to pull pedal up. Question is where does the front of said spring attach to ?
Stretch
Old 06-12-2022, 05:35 AM   #94
sugarmaker
sugarmaker's Avatar
Stretch
Stretch,
This could be similar question John (42 Deluxe) has on his 42 and 48 cars??
Would it go to the same place? Need pictures of front spring attachment point.
Regards,
Chris
1932 AAB Truck
1953 Ford Jubilee
1965 Mercury Comet Caliente
1966 Ford F100
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
Old 06-12-2022, 09:50 AM   #95
ssffnomad
ssffnomad's Avatar
Got it , did a Google search adding “Fordbarn “ and found pictures. It seems that some Dummy kind of recently put a Zip Tie in the hole to secure Speedo Cable.
Thanks, Stretch
Old 06-20-2022, 07:40 AM   #96
ssffnomad
ssffnomad's Avatar
Help please. Could you please post a picture of 39’ passenger car Glove Box and Hinge. ? I can’t seem to get a handle on getting it back together after taking apart months ago . T/Y. Stretch
Old 06-20-2022, 07:33 PM   #97
ssffnomad
ssffnomad's Avatar
Good Evening
Old 06-30-2022, 11:50 AM   #98
ssffnomad
ssffnomad's Avatar
Please identify these parts .
Old 06-30-2022, 12:09 PM   #99
marko39
Glove box springs?
marko39 is offline   Reply With Quote
Old 06-30-2022, 02:20 PM   #100
ssffnomad
ssffnomad's Avatar
Ok makes sense , t/y.
So get the Door and Hinge mounted, then clip on springs ?
Stretch
