#1 | |
'Course, I have other ways of doing it, too. When I'm working on modern cars, and simply flushing the system, I use a vacuum pump system, working through a glass jar. That way I'm able to see when the contaminated fluid ends, and fresh fluid starts. For this scenario, I finish with a couple of aggressive pumps on the pedal, in attempt to flush whatever wheel cylinder I'm working on. And, for really difficult systems, and only once have I done this, I have pumped the fluid backwards. An aircraft mechanic taught me this, many years ago. And, if I happen to have a helper, I've done the 'hold the pedal down, let me pop the bleeder, close it'. Worse situation I've run into, is 'home-builts', where the fabricator routed a line from a high-mounted m/c, down to the frame, then, somewhere along the plumbing path, the line was routed higher (usually to go over something). This creates a place for air to collect, and a spongy pedal. Air won't work it's way out of one of these 'trapped' high spots. I have a friend with a Bonneville Studebaker, with the brakes plumbed this way. And, he is always fighting a spongy pedal. He can bleed, and bleed, and get a firm pedal one day. Next morning, it's spongy. Obviously, lengthy, windy opinion. |
#2 | |
#3 |
Anyone have the Ford Training manual telling exactly how the Ford Lockheed Style brakes were to be bled, including the wheel sequence?
#4 |
In response to post 64...
Sorry, I don't have a training manual. I have two manuals that are identified as published by Ford Motor Company, one from 1942, and one from 1948. Neither exactly address your question, but rather, use words like "repeat at the other three wheels". (not an exact quote) edit... in an effort to address the question in post 64, I've looked at more manuals. I have found several manuals that specify 'sequence'. Just one example is the 1950 Motor's Manual. It says "Start at the wheel cylinder to which the brake fluid travels the greatest distance from the master cylinder (right rear wheel)." Further on it says "repeat the process on the other wheels in turn, always moving to the wheel which is the greatest distance from the master cylinder of those remaining to be bled." (... a 'windy' way of agreeing with post 62.) Last edited by bobH; 11-03-2020 at 12:29 PM. Reason: added sequence |
#5 |
Guys...going to be in the 60's this coming weekend up here in Northern Michigan so I'll have the chance to get at this again.
Fordy I ran a copy of your write up and will start sometime later this week. Thx all....Mike |
#6 |
I bought one of those rear hub removal tools and will try to take off the drum another day. Sure a lot of drama related to all this !! Geez.... Thx...Mike |
#7 |
The MC does not "create" pressure. Your foot, the length of the lever, and MC's bore diameter is what creates pressure! You DID have the drum MOUNTED on the axle when this occurred, right? DD
#8 |
I had this issue when i replaced all the cylinders and the master in my 48 plymouth special deluxe. The original master always had a 2 pump pedal once I did the cylinders and new shoes all around. The new master was a three pump pedal. Drivable, but a little scary.
The fix? Jack up the car and adjust the brakes with the adjusting cam so they just spin by hand with tension. Bleed the brakes, and redjust a slight turn. I have a one pump pedal now, and after 5 miles of driving the brakes didnt catch anymore. |
#9 |
This thread should get a special "Longest Running Question" award. But, that's fine if it helps solve the problems.
#10 |
Fordy .....this has really been a learning curve for me. I’m 78 years old and have been in the automotive business since I was 21, but only did one brake job ! I drag raced with Ford in early 60’s but it was always about engine and trans stuff. I love this stuff !
Coop .....yes drum was still on and the leakage poured out the bottom of drum and backing plate. New rear cylinder arrived yesterday and will try to install with new shoes in next few days if weather holds up. Thx......Mike |
#11 | |
#12 |
I used that special tool to pop off the drum from axle and yes it was a pretty good "POP" !! I thought at first I broke something. All is fine there, but the drum will only come off about a 1/2" and is stuck. Is there anything special I can do to bring it home. Brake Drum Puller maybe ? If so who would sell them. I'm making a career of all this for God's sake !
Seery I'm sure it was. Thx...Mike |
#13 | |
Ok, now I'm confused, you used a drum puller and it worked, but now you're looking for a drum puller??? Once the drum "pops" loose, that is it for the puller, after that it is a question of getting the drum off of the brake shoes. This can sometimes be a chore, but there is no puller involved. Did you not like the puller you used? |
#14 |
Mike, I admire and respect your tenacity and your love of the hobby. To remove the "popped" drum turn the top adjusters so shoes are all the way "in". Also turn the bottom adjusters so shoes retract.
Make sure emergency brake is released all the way. Also, "whack" the sides of the drum with a lead or brass hammer to "shake the shoes" and loosen the drum. Some folks try to use a long screwdriver as a lever to pry off the drum side or side a little at a time. Not sure this is the best idea, though. Hang in there. You will prevail. |
#15 |
Once it pops, they are loose. It is the shoes that are hanging up now, and there may be a lip worn on the edge of the drum that doesn't help.
"I'm making a career of all this for God's sake !" Consider it a hands on training course, 4 year collage in some cases!
#16 |
Fordy and Seery thx. I'll try this. I also am looking for a drum puller online to try that too. I sure hope I don't turn 80 before I get this all done !!!
Thx again....Mike |
#17 |
Mike the best hub puller is the KRW style that Winfield Tool Works made. Perhaps there is a Fordbarner in MI that will let you borrow theirs. Winfield doesn't make them anymore. Wish you lived closer, you could use mine. Whatever you do, do not use the old style universal hub puller with the 3 legs.
#18 |
Mr. Seery: I was thinking the same thing. Once a drum is "pulled" there's no such thing as a second puller.
MIKE: If possible, post photos of what you are dealing with. |
#19 |
Fordy and Seery.....BINGO !!!!!!!!!!!!!!!!!!!!!!!!!
Once I turned in the brake adjustments it started to move. I kept tapping the drum and guess what....the damn thing fell off !!!! NOW....you would not believe the mess of fluid and sludge and crap that is in there. I have a big clean up job before I even think of replacing the shows and cylinder. It is such a damn mess I think these are the original brake shoes. Okay...I'm leaving you guys alone for awhile. I have a big clean up to do. Thx again for everything.....Mike |
#20 |
Mike, Great news. Take photos of everything BEFORE, DURING and after you remove the brake shoes. Also, the lower adjusters ride in brass "cam" washers so make sure you clean them really well with brake cleaner. I reassemble the adjusters screws/nuts and cams with a dab of anti seize compound. If you remove them, be sure to take photos of how they are assembled. Be sure to properly reinstall the two bottom adjusters so that the little "dots" on them line up properly in order to adjust your brakes.
When you reinstall the drum, don't forget the little fiber washer/ gasket that fits under the axle nut washer. If you don't have one, make one out of a piece of leather, like from an old belt. Don't use serrated vise jaws on the emergency cable as you will fray and weaken the cable. Look at post # 6 here. https://www.fordbarn.com/forum/showt...xle+nut+washer and here http://www.vanpeltsales.com/FH_web/F...rbrakeassy.jpg Last edited by 19Fordy; 11-06-2020 at 09:47 AM. |
