Mike42:
Here is the correct order for bleeding drum brakes starting with the wheel farthest from the master cylinder and then bleeding each of the other wheels in decreasing distance order from the master cylinder. 1.Right Rear 2. Left Rear 3. Right Front 4. Left Front Bleeding Process Begin at the wheel furthest from the driver and proceed in order toward the driver. (Right rear, left rear, right front, left front.) While the actual sequence is not critical to the bleed performance it is easy to remember the sequence as the farthest to the closest. This will also allow the system to be bled in such a way as to minimize the amount of potential cross-contamination between the new and old fluid. |
