Old 10-21-2024, 08:13 AM   #41
FrankWest
FrankWest's Avatar
Default Re: Condenser for 1933 model B
Originally Posted by 35fordtn View Post
The bracket can be unsoldered and with some flux you have to work quick as to not overheat it, but can be resoldered to a ih1109 condenser
good idea...Can I tack weld it?
FrankWest is offline   Reply With Quote
Old 10-21-2024, 09:50 AM   #42
35fordtn
35fordtn's Avatar
No that would create too much heat. You have to VERY quickly solder it or use a product called lab metal it is a conductive epoxy
35fordtn is offline   Reply With Quote
Old 10-21-2024, 10:14 AM   #43
1957monarchtpc
1957monarchtpc's Avatar
How about a 1933-34 Condenser for a Model C? Wasn’t a B the 1932 Four Banger?
1957monarchtpc is offline   Reply With Quote
Old 10-21-2024, 12:15 PM   #44
DavidG
DavidG's Avatar
Misconceptions abound: there was no Model C, but rather a continuation of the Model B. All '32-'34 four-cylinder heads had a cast-in capital letter C to distinguish them from the Motel A head with a cast-in capital letter B. That did not make a so-eqluipped Model A into a Model B, nor were '32-'34 fours Model Cs with their original standard heads. There's a simple acid test, simply provide a single Ford document that makes reference to '33-'34s as Model Cs. Good luck!
The ignition systems of '33-'34 fours are identical in all respects to the '32 four-cylinder ignition system.
Ford did not manufacture the ignition condensers that they used on their cars. Like today, more 50 per cent of a '33 Ford was manufactured by outside suppliers.
And original NOS four-cylinder condensers are not that hard to find.
William Shakespeare penned a term that is an appropriate subtitle for this entire thread.
Old 10-21-2024, 07:20 PM   #45
alexiskai
alexiskai's Avatar
The Comedy of Errors
Old 10-21-2024, 10:02 PM   #46
DavidG
DavidG's Avatar
That works too. I was thinking of "Much Ado About Nothing".
Old 10-22-2024, 07:02 AM   #47
rockfla
rockfla's Avatar
Alexiskai
After DavidG's post "I" was going to post "Two come to mind" (yours & David's) and that I "think" I could figure out which one DavidG was referring to....BUT I figured most would consider it "pot stirring".......SINCE you stirred the pot.....My hunch was right!!!!
Old 10-22-2024, 08:08 AM   #48
51504bat
51504bat's Avatar
Fast forward to 1971, "Fool's Parade" staring starring James Stewart and George Kennedy.
