Old 02-08-2019, 08:40 PM   #41
ford38v8
ford38v8's Avatar
Default Re: 1935 Ford coupe heater
these old relics? Lack of respect!
Alan
Old 02-08-2019, 09:06 PM   #42
Bullshark
relics (plural noun)
an object surviving from an earlier time, especially one of historical or sentimental interest.
Not at all, I have reason to believe I might have been conceived in one just like this one.
Bullshark is offline   Reply With Quote
Old 02-09-2019, 11:33 AM   #43
blucar
blucar's Avatar
From the looks of it, painting that heater would be a crime. It even has the original decal! Don't do it!
I agree... If it ain't broke don't fix it...
Bill.... 36 5 win cpe
Old 02-09-2019, 02:18 PM   #44
PeterC
PeterC's Avatar
Here is the way I handled the heat in my 35 Three Window Coupe. The pull cable on the dash actuates a hidden on/off valve under the dash the controls the flow of hot water to the 1940 Ford Heater. Also - I did not run the supply hoses through the firewall - rather they run along the passenger inside frame rail in the engine compartment and enter hidden behind the passenger side kick panel up and over to the heater - so as you can see - in the engine compartment and the interior alike - the heater hoses are near undetectable and the heat has precise control!
PeterC is offline   Reply With Quote
Old 02-09-2019, 04:04 PM   #45
kiwitony
kiwitony's Avatar
peterc that's a beautiful car.
kiwitony is offline   Reply With Quote
Old 02-16-2019, 11:42 AM   #46
40ford
40ford's Avatar
Bullshark, did the mounting holes line up on your firewall with the heater?
40ford is offline   Reply With Quote
Old 02-16-2019, 05:31 PM   #47
Bullshark
Yes!! Going to work out fine. Probably wait till it it warms up a little before I install. No heat here in the hanger. Then I won't need it. Lol.
Old 09-07-2019, 12:24 AM   #48
Detonator
Detonator's Avatar
Bullshark: Just bringing this back up. Did you get your heater installed?
Seabright Hot Rods
Detonator is offline   Reply With Quote
Old 09-07-2019, 07:01 AM   #49
KGS
KGS's Avatar
Beautiful cabin Waco! 1937?
KGS is offline   Reply With Quote
