Old 09-09-2018, 10:40 PM   #41
miker98038
miker98038's Avatar
Default Re: Trouble finding an air filter
Don’t feel bad, K. I don’t remember much about my brother’s 65 390 4 speed in 1967. And I did all the maintenance.
miker98038 is offline   Reply With Quote
Old 09-10-2018, 04:21 AM   #42
KULTULZ
KULTULZ's Avatar
Exclamation Re: Trouble finding an air filter
Originally Posted by KULTULZ View Post
If you can, I need measurements of your ACL ASSY itself, not the element, diameter and standing height (measured on bench) along with diameter of lid.
What have you decided on the HEATER CONTROL VALVE?
If you can Herman...
I would like to try and ID the ACL itself.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 09-10-2018, 07:22 PM   #43
Bleach
Bleach's Avatar
Sorry but I probably won't have time until Friday. Can it wait until then?
I'm still using the original valve but moved it slightly upstream. I added an elbow at the original valve location and attached the valve with a short of heater hose to the elbow.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Bleach is offline   Reply With Quote
Old 09-11-2018, 09:41 AM   #44
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Trouble finding an air filter
Whenever you can get to it will be appreciated. I want to find the rhyme and reason for the odd 1964 ACL.
THANX!
Old 09-14-2018, 10:09 AM   #45
Bleach
Bleach's Avatar
OK here are the measurements of my ACL.
The body is about 4-7/8" tall by about 18" in diameter, not including the snorkel.
The lid is 1-1/2" tall by 10-1/4" in diameter.
I took some photos as well.
Old 09-14-2018, 11:36 AM   #46
KULTULZ
KULTULZ's Avatar
THANX!
The plot thickens -
Old 09-14-2018, 11:54 AM   #47
Bleach
Bleach's Avatar
Could it be an Edsel ACL? I did check for Edsel air filters but none matched the dimensions for height.
Old 09-14-2018, 12:16 PM   #48
KULTULZ
KULTULZ's Avatar
It could very well be, but EDSEL (part of MEL) cataloged its parts in a separate/dedicated text.
At one time ... ... I had complete cataloging (other than EDSEL) but got rid of it as I thought it was no longer needed. But I am a moron so nothing new to report here.
The photo you show is the 58 FE 361 (E-400). There is also a 410 MEL that may be unique also.
CORRECTION- I just noticed the photo is a 59 EDSEL. EDSEL dropped the MEL 410 for the 59 model run and I thought (need to verify) offered the FE 332 and 361 but I am not sure of those rocker covers. They are 58 unique if I remember correctly.
Eh, it will give me something to do ...
EDIT- (Fr. for I think I got it right this time)
Engine Colors
  • Semi-gloss Black: (1268 parts PPG DAR-9000 to 633 parts PPG DX-265)
    • Block, heads, intake manifold, oil filler tube, oil pan
    Gloss Black:
    • Brackets, generator, fan, pulley, starter motor, inner fender aprons, radiator
    Off-White: (Same paint scheme as the 1958 E-475, without the red stencil:
    • Air Filter cover, valve covers
  • Natural:
    • Transmission bell housing, distributor, exhaust manifolds, fender attaching bolts
SOURCE- http://www.edsel.com/pages/edsel59.htm#Engines
Old 09-14-2018, 02:49 PM   #49
Bleach
Bleach's Avatar
This is the book that I have. I got it thinking it would help me find the filter I needed. Wrong plus now that I know from you that there are other books covering the other makes.
It's not a total waste. It has listings for all the other parts and specs the FSM does not show for my 56 Ford.
I can take photos fairly easily now. I found an old smart phone that I have that is compatible with my old macbook. It's a Motorola. It doesn't take the greatest photos plus my hands shake makes it harder. My iPhone which is fairly new will not work with my mac. What a bunch of BS. It takes great photos but are a big PITA to download.
Old 09-14-2018, 03:10 PM   #50
KULTULZ
KULTULZ's Avatar
That is a quick reference catalog, comparable to today's MOTORCRAFT QUICK REFERENCE CATALOG(s).
It only gives some fast moving part numbers. More detailed info needed will be found in the MASTER PARTS CATALOG of the period.
Old 09-14-2018, 03:18 PM   #51
Bleach
Bleach's Avatar
Like one of these?
Old 09-14-2018, 05:26 PM   #52
Bleach
Bleach's Avatar
I've also found I have a couple of catalogs for 58 & 59 Edsels but none have any specific info for air filters other than the part numbers, B8E-9601-A & B.
Old 09-15-2018, 05:39 AM   #53
KULTULZ
KULTULZ's Avatar
Post Re: Trouble finding an air filter
Like one of these?
Those are model year bound catalogs. They contain info on one or maybe two or more model years. FORD decided to combine years as time went on and cataloging became more cumbersome into MASTER PARTS CATALOGS (usually loose leaf but also bound) which combined several model years (ex as seen now 49/59 - 60/64 - 65/72 - etc.).
PS - Don't let those get away as they have original info that was later deleted from the MPC.
Old 09-15-2018, 05:47 AM   #54
KULTULZ
KULTULZ's Avatar
You have what?
Can you look in the EDSEL catalogs and see if size dimensions are given for the air cleaner housings themselves (BASIC PN 9600)?
No big hurry, when and if you can.
Old 09-15-2018, 07:31 AM   #55
Bleach
Bleach's Avatar
That was the 1st thing I checked and there wasn't anything that specific. It only has part numbers and a few illustrations for all the models. The 59 book looks like only a supplement to the 58 book.
Old 09-15-2018, 07:33 AM   #56
KULTULZ
KULTULZ's Avatar
THANX! for sharing that.
I've never come across an EDSEL CATALOG.
Old 09-15-2018, 07:34 AM   #57
Bleach
Bleach's Avatar
They're not going anywhere, including the Edsel books. Interesting thing, the Edsel books also contain Canadian info.
