Old 03-09-2012, 03:18 PM   #21
CarlG
CarlG's Avatar
Default Re: shock conversion
OK, My truck had the friction type shocks on it when I bought it. They were no doubt installed on it when it was "restored" about 20 years ago. While the ride seems "OK", I have thought of putting original type shocks on it. If I were to purchace a set of Stipe shocks, what else would I have to buy in order to be able to install them correctly?
Old 03-09-2012, 09:19 PM   #22
KGBnut
KGBnut's Avatar
If you are thinking of going with tubular shocks, I'm with the 'Ken Davis' group. I can't say enough about them. Work great and easy to install.
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 03-09-2012, 09:47 PM   #23
400A-64
400A-64's Avatar
Brent , to answer your question...Nothing!! I had one of the flat bars break.
That's when I had a set of originals rebuilt. ( should of rebuilt them in the first place)
Bruce Davis [email protected]
400A-64 is offline   Reply With Quote
Old 03-10-2012, 07:28 AM   #24
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Well without seeing a visual on what you have, the 'textbook' answer is going to be that after Bill Stipe's shocks are mounted with the correct style bolts, you will need a set of shock arms and the bolt/nut/cotter pin that locks it onto the shock, ...and you will need a link to connect the arm to the perch/housing mount. There are a couple of options but originally they used a Tubular Link (which can be purchased from Vendors) or some folks use the later style links often referred to a "dogbones". Therefore you will need shock mounting bolts, shock arms, links, and the hardware for the previously two mentioned items.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-10-2012, 08:49 AM   #25
theHIGHLANDER
Well, I'm shocked at the varied opinions
Tube, lever, friction, gas, adjustable. It's a damper as we all know. Consider the weight and the desired control. Consider your normal driving conditions. I live in a MI county that has no road money so my roads suck.
IMO, it's hard to beat the real deal. It can be copied with friction shocks but not for long. I can't speak to a tube conversion, but I'm thinking the angle of mounting will also have a lot to do with the shock's performance. Think about how the axle reacts to a bump or drop in the road. It surely does not move straight up and down. Do these new kits consider that? The more linear the action is to the axle the better the damping. If the shock is too vertical it will dampen more than you want it to because it's "moving faster than the axle". Make sense? This is the reason the ball joint links connect the levers to the axles, so they can offer linear damping to the natural twist of the buggy spring mountings. Someone mentioned Speedway. Good idea. Take a look at some of the hot rod set ups and note the angles that the shocks are mounted when using the single spring. Some of the more pricey front suspensions are very well designed and can offer some perspective. I personalyl would rather have the OEM stuff, but I can see that prices for those parts has become a bit high. I can buy used 30s Packard shocks cheaper sometimes!
theHIGHLANDER is offline   Reply With Quote
Old 03-10-2012, 10:03 AM   #26
1931 flamingo
1931 flamingo's Avatar
The OEM stuff w/links was mounted vertically....................
Paul in CT
Old 03-10-2012, 03:25 PM   #27
jan bogert
jan bogert's Avatar
i had the ones that the bottom bracket got u bolted to the axle. NO GOOD i moved the bracket to the front radius rod behind the shackles. no they are faceing inward and forward slightly. THEY WORK PERFECT. i can push down on the bumper it comes up with no bounce
jan bogert is offline   Reply With Quote
Old 03-12-2012, 09:10 PM   #28
Kahuna
Kahuna's Avatar
I am using the MGB rear lever shocks on the front of my 32 Model B. Seem to be great
Kahuna is offline   Reply With Quote
Old 03-14-2012, 07:39 AM   #29
theHIGHLANDER
Originally Posted by 1931 flamingo View Post
The OEM stuff with links was mounted vertically....................
Paul in CT
