Old 03-01-2012, 02:27 PM   #21
rickmass
Default Re: 1936 Ford with 59ab motor
Thank,s flat jack 9 Rickmass
rickmass is offline   Reply With Quote
Old 03-02-2012, 08:58 AM   #22
Robert Dip
Robert Dip's Avatar
Working on my '35 3W and installed a '37 steering box with matching frame steering mount. My old Fentons would be perfect....but....my only problem is that they do not clear the oil dip stick base / tube....on both the original '35 engine and a 59AB that is ready as a back-up engine. I am surprised that there are not to many comments on the dipstick clearance. The only way to have a proper clearance is to actually re-locate the base of the dipstick on the oil pan. I will eventually use the Fentons ( just because I like them ) but, in the meantime, I have received the entire dual exhaust & headers from Red’s. In communicating with someone on this dipstick issue, I was told it cleared???? One of my 8BA motors, the stick is placed forward and clears the Fentons perfectly. I am at a loss with this.
Robert Dip is offline   Reply With Quote
Old 03-02-2012, 09:30 AM   #23
Seth Swoboda
Seth Swoboda's Avatar
The Fenton headers will not clear your steering box. The Fenton cast iron headers would not fit my 39 pickup. They will not clear the steering box even after grinding away some material for clearance. I hung the fentons on the wall and bought a set of Red's headers and was very pleased with them.
Seth Swoboda is offline   Reply With Quote
Old 03-02-2012, 09:44 AM   #24
flat-v8
flat-v8's Avatar
I got my Fentons to fit perfectly on my 36' p\u with 59A motor, but they did not at first. Right side no problem, left side hit stock steering, started grinding, checked, grind some more, checked, grind more until I went thru, made a hole! So I took it to a welder friend who dented it in just enough and sealed the hole, now they fit perfect and sound great! In the long run it was still worth it.
flat-v8 is offline   Reply With Quote
Old 03-03-2012, 07:37 AM   #25
Roadster5040
Roadster5040's Avatar
Just received my reds headers today can,t wait to install going on my 37 pickup call reds they are very hepful
Roadster5040 is offline   Reply With Quote
