Old 06-04-2026, 07:54 PM   #21
old ugly
old ugly's Avatar
Default Re: steering gearbox oil
Originally Posted by Bob Bidonde View Post
that is a good idea adding that grease fitting in between those sector bushings. but i would make sure that the grease fitting is in between the bushings or you will not be able to pump grease in there. double check that bushing measurement when the sector is out to make sure.
All im trying to say is don't trust that service bulletin measurement.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 06-04-2026, 08:59 PM   #22
Klattu1929
Ref:17, I had looked at that SB and wondered if it was applied to the 2-tooth gearbox's. Took a quick look through the SB but didn't see anything adding a fitting to the 2-tooth, or not adding it to the 2-tooth gearbox. I don't know if cornhead will flow good enough to get to the bushings, So with cornhead a grease fitting sounds like a good idea for the bushings. I'm not interested in the needle bearing setup so that's not part of my equation.
I added the fitting to my existing 7-tooth, mainly because I had the gearbox disassembled so why not add it. And I have used it to grease the bushings. Now I have this 2-tooth tore down, I think a grease fitting is in the cards for this 2-tooth, anyway, it's a jalopy, not a points car.
Klattu1929 is offline   Reply With Quote
Old 06-04-2026, 10:35 PM   #23
Ruth
Yep, I installed a grease filling along with the O-Ring kit. Solved any leakage. I use Lucas 85W-140 grar Oil.
Ruth
Old Yesterday, 08:08 AM   #24
updraught
updraught's Avatar
Originally Posted by rotorwrench View Post
There used to be a video of a gearbox cut away for a viewing window so folks could see how it flows with movement of the gears. I believe it was put out by John Deere. The corn header used by JD has a gearbox with no less than four shafts to turn all the pick up and cutter works in there.
My guess is that those having problems have not cleaned out the steering box properly. It should work fine on slow moving gears.
https://youtu.be/7zNhli-J0Gk?si=ffkxgyTUXAQr350F
updraught is offline   Reply With Quote
Old Yesterday, 10:44 AM   #25
JRrev
JRrev's Avatar
Thought about JD Cornhead grease in my two tooth gear box but I read that it liquifies with heat being generated. Decided not to as there's not much heat generated in steering vs. constantly rotating gears/bearings. I'm sticking with my Penrite. I do use Cornhead in my brush hog's gear box.
JRrev is offline   Reply With Quote
