Old 05-14-2026, 02:00 PM   #21
Terry Burtz, Calif
Default Re: Does flywheel need to be balanced
Originally Posted by Seth Swoboda View Post
As I said, balance the entire rotating assembly. You don't need to be a genius to figure this out. Any competent automotive machine shop will do this without question.
Competent builders and machine shops are hard to find. Everything needs to be balanced separately. We have builders of the new engine that don't understand this and have the flywheel and pressure plate balanced together by only removing weight from the flywheel.
Ford engineering in the 1920's was behind the competition. In 1914, the Dodge Brothers left Ford and started making their own automobiles. By 1927, their 40 HP Fast 4 engine used inserts on the 5 main bearings and 4 connecting rods.
Terry Burtz, Calif is offline   Reply With Quote
Old 05-15-2026, 09:29 AM   #22
old31
I am going to make a wild guess that Ford's engineers knew a 5 main was the way to go. But Henry, being Henry, knew that a 3 main was cheaper and that is what he did.
Old 05-15-2026, 04:30 PM   #23
old ugly
old ugly's Avatar
i think in the late 1920s selling an affordable car that Ford could mass produce cheaply was more important than having a bit of vibration.
the first Model A was completely solid mounted engine and tranny (which mine is). so without isolating the engine and trans assemblies there is bound to be vibration.
Competition and consumer knowledge is what made cars nicer all around. If it wasn't Ford would still be building and selling Model Ts
I kinda like driving old sh&# the way it was made 98 years ago.
Embrace the vibes.
old ugly
my mom would have told me. "these things are here to test us"
old ugly is offline   Reply With Quote
Old 05-15-2026, 05:28 PM   #24
ursus
Chevrolet introduced its 6-cylinder engine in 1929 and, until the mid-30's, it ran only three main bearings of cast babbitt construction. My Dad's 1929 Chev could reach 70 MPH (on a good day) but there were some nervous vibrations along the way.
ursus is offline   Reply With Quote
Old 05-16-2026, 09:30 AM   #25
Flathead
Flathead's Avatar
Absolutely. When you balance flywheel and pressure plate together you have really not balanced anything, if the pressure plate ever needs replacing you must start over to maintain balance.
Flathead is offline   Reply With Quote
Old 05-16-2026, 12:39 PM   #26
nkaminar
nkaminar's Avatar
When in 1969 I worked for a company that produced gas turbine engines, the components were all balanced individually and then assembled with no further balancing. The components were the compressor and exhaust disks with the blades attached. I cannot remember if there was a separate shaft, but it there was that was balanced separately.
Old 05-18-2026, 12:45 PM   #27
40 Deluxe
Originally Posted by Joe K View Post
I agree with Brent too.
Be careful the balancer/machinist doesn't "squeeze" too hard between centers and permanently deform the crank.
Joe K
This is new to me. How does a balancer "squeeze" and deform a crankshaft?
Old 05-18-2026, 01:09 PM   #28
nkaminar
nkaminar's Avatar
If the balancer is using centers at the ends of the crankshaft. The crankshaft has conical holes drilled in each end that was used to grind the bearings and is used to balance the crank. If the balancer presses in too hard on the ends it could possibly deform the crank at the flanges for the rod journals. The force is off center at those flanges.
Beware that sometimes the centers, the conical holes, are not on center and the journals at the ends should be used.
Old 05-19-2026, 09:19 AM   #29
Fullraceflathead
Fullraceflathead's Avatar
When he says the word balancer he's referring to the machinist or machine operator of the balancing machine.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 05-19-2026, 11:19 PM   #30
Dan McEachern
Not an expert, but most balancing machines support the part on the journal or shaft surface- not between centers.
Dan McEachern is offline   Reply With Quote
Old 05-20-2026, 06:27 AM   #31
nkaminar
nkaminar's Avatar
That would be the best method. There is no guarantee that the centers are true.
Old 05-20-2026, 07:19 AM   #32
Kurt in NJ
Kurt in NJ's Avatar
I have been working on alignment of the headstock and tailstock on my crankshaft grinder and with a skinny model T crankshaft and wondering what distortion is induced by varying the pressure on the centers and saw no changes with different pressures on the centers from the tension spring on the runout of the center main
