#21 |
#22 | |
Completely agree with you. I have had problems with two disconnects so now all I do is have a 1/2 inch wrench in the car to disconnect the battery. Never wore out a terminal either.
#23 |
+1 on the Cole-Hersee I think I bought mine off of eBay, I made sure it was an older one made in the USA.
#24 |
My 2 cents on which post to use for the battery disconnect. Think about when you disconnect the battery. You disconnect the ground first. That way you don't accidentally touch the hot cable to a ground source when disconnecting the hot cable with the ground still connected. JMO
Edit: but some sanctioning bodies specify that the hot side be used. For NHRA compliance, use heavy-duty 1-gauge or 2-gauge welding cable for battery disconnect switches, especially with trunk-mounted batteries. The switch must be on the positive side, interrupting all electrical power, with the alternator wired to ensure the engine stops immediately when the switch is engaged For Bonneville Land Speed Racing (SCTA rules), the battery disconnect switch must be installed on the positive side of the electrical system and act as a master cut-off for all electrical functions, including the alternator and ignition.
Making the simple complicated for over 30 years. Last edited by 51504bat; 04-21-2026 at 12:26 PM. |
#25 | |
I do agree with the third and fourth paragraphs. |
#26 | |
If you disconnect the ground first the hot post of the battery can lead to a spark if mistakenly touched to ground such as loosening the bolt on the cable end and momentarily touching the wrench to ground. Up to you which order you choose to use.
Making the simple complicated for over 30 years. |
