Old 09-20-2025, 08:49 AM   #21
nkaminar
nkaminar's Avatar
Default Re: Big oil loss on rear sid
In general Bronze will wear better, but Aluminum is good for many miles. It really depends on the alloys used for the Bronze and Aluminum.
Old 09-20-2025, 01:55 PM   #22
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
Werner, The advantage of a bronze bearing seal is that it has a thrust shoulder. If the thrust on the rear main is broken or cracked the aluminum seal can be replaced with the bronze seal and help prevent crank forward movement. The bronze is stronger than the type 11 babbitt I use. When doing a complete babbitt job I use them to take the stress of the other 3 thrust shoulders. I have successfully used them as a partial fix when a club member wants to keep his car on the road. Dan
dansluck is offline   Reply With Quote
Old 09-20-2025, 02:19 PM   #23
Gene F
Gene F's Avatar
Originally Posted by dansluck View Post
Werner, I would remove the rear cap and check the clearance with plastic gauge (green) if you can get it. Another option is to use aluminum foil. A strip folded to about 3/8 x 2 inches (measures .002 of an inch thick) in the rear cap. Turn with hand crank just a little to see if it moves. It should not. It should hold with 2 strips and turn with 1 strip. Remove shims as needed. If the thrust is broken in the block check out Berts Model A Store on-line for a bronze rear main seal with thrust. Part # A-6336. Good Luck! Dan in Reno Nedada
"Bronze Rear Main Thrust Washer- USA made. Replaces the A6335 rear main seal. Gives the engine a better rear main thrust surface." dansluck, how do you even install that thing? Can he do it with the motor in the car?
Gene F is offline   Reply With Quote
Old 09-21-2025, 01:44 PM   #24
Werner
Werner's Avatar
Originally Posted by Gene F View Post
... how do you even install that thing? Can he do it with the motor in the car?
Yes, that would be very interesting to me as well. I found this video:
https://www.youtube.com/watch?v=8MH3HtTnshQ.
According to it, the installation only requires to remove the oil pan. If I understand correctly, that's related to the crescent-shaped sealing washer too.
Dankeschön!
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 09-21-2025, 04:09 PM   #25
Charlie Stephens
Did you remember the gasket between the block and the flywheel housing?
Charlie Stephens
Old 09-23-2025, 02:22 PM   #26
Werner
Werner's Avatar
Charlie Stephens
The oil isn't dripping along the oil pan, but only from the clutch housing. -
Has anyone ever done this repair from underneath with the engine still installed?
Werner
Citroen 11 CV, 1947
Old 09-23-2025, 03:18 PM   #27
Benson
Charlie Stephens
I agree that if missing or gasket is damaged that this gasket will leak from bottom of flywheel housing AKA "clutch housing".
Benson is offline   Reply With Quote
Old 09-23-2025, 03:51 PM   #28
Werner
Werner's Avatar
Benson,
thanks, but I can not open the attachment.
Werner
Citroen 11 CV, 1947
Old 09-23-2025, 04:15 PM   #29
nkaminar
nkaminar's Avatar
I had the leak between the flywheel housing and block that has been talked about. The only cure was to take the engine out, use a different flywheel housing that was flat, and put the gasket in with plenty of gasket cement. The oil was dripping from the bottom of the flywheel housing. In my case I had to take the exhaust manifold off to see the leak.
Old 09-23-2025, 04:32 PM   #30
The Master Cylinder
The Master Cylinder's Avatar
Sometimes it helps to put fluorescent dye in the oil (or coolant) to trace a leak. You can see the leak with an ultraviolet light and trace it to it's source.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 10-27-2025, 11:42 PM   #31
MrWrench
So what did you do to fix the Babbitted main cap? I am faced with a rear main cap almost the same. I’m hoping I can get a shop that can repour my lower cap half and mill it, fingers crossed!
MrWrench is offline   Reply With Quote
Old 10-28-2025, 10:31 AM   #32
The Master Cylinder
Since I planned on keeping this car and touring, I decided to pull the engine and have it completely rebuilt with inserts installed at the advice of my machinist because I don't want any (hopefully) issues down the road.
The Master Cylinder
Old 10-28-2025, 10:51 AM   #33
Werner
Werner's Avatar
I haven't done this work yet. I've been a bit ill and can't lie under the car for long periods of time.
But I took an oil sample, and spectral analysis didn't reveal any noticeably increased metal abrasion.
Werner
Citroen 11 CV, 1947
Old 10-28-2025, 11:27 AM   #34
The Master Cylinder
When the bearing comes apart in chunks, like mine did, it may not show any metal abrasion!
The Master Cylinder
Old 10-31-2025, 03:59 PM   #35
Werner
Werner's Avatar
Hallo und guten Abend.
I've only made a little progress. The two nuts on the rear bearing cap are so tight that I can't loosen them.
I'll have to try it again with an impact wrench tomorrow. In the oil pan, I only found a little steel shaving, 3 x 2 mm and 0.05 mm thick.
However, the aluminum camshaft gear was rubbing against the cork gasket that protrudes on the inside. Since the oil pan and filter screen were clean, the sludge is in the oil filter.
A note for those who insist on using unalloyed motor oil: The picture shows how clean the oil pan and the intermediate plate are. They were only degreased with brake cleaner. I use exclusively 20W-50 HD Oil classified API SC.
Bis morgen, beste Oelfinger Gruesse!
Werner
Citroen 11 CV, 1947
Old 10-31-2025, 04:08 PM   #36
Y-Blockhead
Y-Blockhead's Avatar
Please don't use that blue silicone gasket sealer. I have seen way too many expensive engines ruined because of it. Although the Model A engine does not have a lot of oil passages, it does tend to plug things up.
Old 10-31-2025, 04:30 PM   #37
Benson
I agree.
Same problem with the orange silicone gasket sealer!
More that a few times I have seen it plug up oil drain passages and oil drain pipe in rear main bearing caps especially when too much was used.
Pieces of the silicone break loose and flow down passages and plug them up.
Old 10-31-2025, 05:23 PM   #38
Werner
Werner's Avatar
Yes well, thanks for the important/helpful information. That's thick "Hylomar H" what I use. It was also called "Rolls Royce Paste" 50 years ago. It stays soft.
What recommendations do you have, please?
Dankeschoen!
Werner
Citroen 11 CV, 1947
Old 11-01-2025, 07:44 AM   #39
Randall
Randall's Avatar
Werner , put a piece of pipe on your tool to break it loose https://youtu.be/8MH3HtTnshQ?si=5Cu0E0l7BJ8JgZsJ
Randall is offline   Reply With Quote
Old 11-01-2025, 09:36 AM   #40
TomInCologne
TomInCologne's Avatar
Dankeschoen!
I‘ve seen people applying it with a roller, so you only have a very thin layer and any additional amount can be cut-off prior to putting everything together again…
Bitte sehr…
TomInCologne is offline   Reply With Quote
