#21 |
If your original engine is too far gone to economically get running well you should consider swapping in another flathead Ford V8. Any 39 through 48 engine is basically a drop in, and a 49-53 engine can be made to bolt in with careful selection of outside parts (water pumps, pulleys, oil pan, bell housing, etc.).
Let us know how your compression tests go (dry, then with oil added), and we can help you further. This doesn't have to break the bank, and does not require swapping in an overhead valve engine. |
#22 | |
I did do some brake work a while back. The master cylinder says "Lockheed". It must be original. Lockheed aircraft partnered with Ford in 1939 to help with hydraulic brakes. It was rusted solid. I replaced it. But likely need to rebuild each slave cylinder. Maybe I will have working brakes at that point |
#23 | |
I did do some brake work a while back. The master cylinder says "Lockheed". It must be original. Lockheed aircraft partnered with Ford in 1939 to help with hydraulic brakes. It was rusted solid. I replaced it. But likely need to rebuild each slave cylinder. Maybe I will have working brakes at that point. I really would like to see if I can produce a spark at the plugs. I need a distributor to make that happen. I understand the need for a compression check. I had a compression checker some where. Haven't seen it in years. Maybe I need to buy another. An after market distributor was around $400 last time I checked. Always something comes up that depletes any money I save. Its called living. Next thing I know, another year (or 2) goes by, and there she sits. Additionally. I wouldn't know a stuck valve if it hit me in the head. I have worked on cars all my life. Now 70. When I grew up, points were the norm. But I never owned a flathead. It is a source of frustration and shame to me. It is a pretty yard ornament. It only moves if loaded on a trailer or rollback. These are the thoughts that cause me to consider another engine. One that will run. That or sell it. Thanks for all the good advice. Last edited by 1939Deluxesedan; 08-05-2025 at 09:32 AM. |
#24 |
1939Deluxesedan
Where are you located??? I think I have a distributor I changed out on one of my cars that I know is good and a coil I use on my Sun Machine, it has not been re-done by Skip BUT I know it will work for you to at least draw a spark that I could send to you as long as you send it back once you figure out what direction you are going to take. |
#25 | |
#26 |
#27 |
My advice would be to stay away from any aftermarket electronic (or points, for that matter) distributor and use a properly set up stock unit. You'll probably save some dough, too.
#28 |
