Old 05-04-2025, 11:38 AM   #21
TomC750
TomC750's Avatar
Default Re: 1941 cooling
Originally Posted by 38 coupe View Post
I agree with ford38v8, you don't have a problem to fix. 3/4 hot on a stock gauge is 180 F, normal operating temperature for a flathead V8. What you have is an engine with wear, but not worn so bad it needs a rebuild. If there is any oil pressure at idle, and no bad sounds, then drive with confidence.
Thanks 38 coupe. I have a better prospective of where I am at. I took temperature readings at the radiator tank with a good cooking thermometer. it has along stem that reaches well into the water. I blocked the radiator with cardboard and ran the engine at fast idle. Even with the rad blocked it took a while to warm up. When the dash gauge was in the middle, my thermometer read 180*. When it continued to warm up and the dash gauge was all the way to the right on the furthest mark my thermometer read 195*. Looks to me like I am OK. I decided I would remove the thermostats prior to flushing, only to discover there are none! I will order. It may be that it will run cooler without the coolant circulating so fast. I have not flushed yet, did not buy enough for a 24 qt system! Will tomorrow.
TomC750
1949 8NV8 Ford tractor
1930 1 Ton White
1941 Mercury Sedan Coupe
TomC750 is offline   Reply With Quote
Old 05-04-2025, 11:54 AM   #22
38 coupe
38 coupe's Avatar
Temperature gauges and sending units can drift with age. Good idea calibrating yours, I keep a cooking thermometer in the shop for the same reason.
I like to run 160 F thermostats in pre-war Fords. I run 180 F thermostats in 8BA engines.
Old 05-04-2025, 10:23 PM   #23
SoCalCoupe
SoCalCoupe's Avatar
One thought; Three recommendations:
1) your oil pressure readings are consistent with my experience.
2) Good thing I didn't trust my temp gauge. I bought an inexpensive "Kizen Infrared Thermometer Gun" and determined my temp gauge was reading way high.
3) bought a NOS temp sender and achieved consistent reading between thermometer gun and dash gauge.
3) Thermocure is the cooling system flush version of Evaporust. I highly recommend it. I cleaned A LOT of junk out of my cooling system that I thought was clean. I could tell a noticeable difference in the weight of the gallon bottles of coolant I drained using Thermocure vs. the weight of coolant with no flush. It was as black as charcoal.
SoCalCoupe is offline   Reply With Quote
Old 05-05-2025, 04:11 PM   #24
Seth Swoboda
Seth Swoboda's Avatar
Whenever you use Thermocure, does the junk it cleans out plug the tubes in the radiator?
Seth Swoboda is offline   Reply With Quote
