Old 09-26-2024, 04:00 PM   #21
mcgarrett
Default Re: Marvel Carb User Group
Originally Posted by 1930artdeco View Post
McGarrett what paint did you use?
Mike
1930Artdeco,
After a good solvent cleaning in my parts washer, I spray the carb body with brake cleaner as a final cleaner because it because it removes any grease or oil films and dries without leaving any residue. Then painted with VHT gloss black engine enamel.
mcgarrett is offline   Reply With Quote
Old 09-26-2024, 10:57 PM   #22
47topless
47topless's Avatar
Been looking for a Marvel carb for my '31 but all I can come up with are carbs for tractors.
I have nothing against tractors, but I would like to use a carb specifically made for an old Model A banger.
47topless is offline   Reply With Quote
Old 09-27-2024, 04:57 AM   #23
rer_239
rer_239's Avatar
Just put one on my 29,and so far I like it. Now I have to put heli coils on my spares mounting flange
rer_239 is offline   Reply With Quote
Old 09-27-2024, 12:00 PM   #24
Cape Codder
Cape Codder's Avatar
49topless I have a Marvel carb but with all my problems have yet to try it on my A. You mentioned that all you can find are Tractor carbs. Can you please tell me the difference between a car carb. and tractor carb. ?
I don't care if the "A" Starts BUT sure WANT IT TO STOP!
Cape Codder is offline   Reply With Quote
Old 09-27-2024, 01:35 PM   #25
Technite73
I am in.
Technite73 is offline   Reply With Quote
Old 09-27-2024, 05:13 PM   #26
The Master Cylinder
The Master Cylinder's Avatar
Originally Posted by JOHN CT View Post
http://rennerscorner.com/index.html?m
I think they are the only ones that carry carb parts
Mike's has gasket kits and rebuilt Marvels.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 09-27-2024, 05:24 PM   #27
The Master Cylinder
An acquaintance is so anal he copied and made his own Marvel Schebler decal for his Marvel.
The Master Cylinder
Old 09-27-2024, 06:04 PM   #28
electricman
I am also in. I have been impressed by the improved performance of the Marvel over the Zenith or the Tilly.
electricman is offline   Reply With Quote
Old 09-28-2024, 09:54 AM   #29
Don S
Count me in . Had my marvel for a couple of years ,no issues,much better performance than my Zeniths. I made a micarta ( fenolic ) spacer between carb and manifold, prevents heat soak down from intake manifold to carb, when engine shut down, helps to prevent fuel expansion and fuel drips.
Don S
Don S is offline   Reply With Quote
Old 09-28-2024, 10:28 AM   #30
David in San Antonio
David in San Antonio's Avatar
I’m in. Already tried Zeniths, currently running a Tillotson, but I like the idea of more power. The pot metal body does not worry me.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 09-28-2024, 04:14 PM   #31
Y-Blockhead
Y-Blockhead's Avatar
Here is an excelent thread from Ford Barn past on Marvel Schebler Carburetors. A lot of good information. https://www.fordbarn.com/forum/showthread.php?t=139836
Thanks for posting a picture of my Marvel Master Cylinder.
Old 09-29-2024, 08:00 AM   #32
47topless
47topless's Avatar
Codder,
I am very unfamiliar with the Marvel carbs and I do not know if those used on tractors, are the same or different that the Marvels used on Model As. I'm trying to learn as much as possible about, what seems to be, a very good carb for my Model A.
Thank you
Old 09-29-2024, 09:34 AM   #33
JBill
Anybody have contact information on the place that sells rebuild kits for the Marvel-Shebler?
JBill is offline   Reply With Quote
Old 09-29-2024, 09:54 AM   #34
The Master Cylinder
Renner's Corner has most parts for the Marvels.David has (or had) some used parts also. https://www.rennerscorner.com/carburetor.html
The Master Cylinder
Old 09-29-2024, 10:18 AM   #35
Fullraceflathead
Fullraceflathead's Avatar
I believe the tractor carburetors do not have the GAV adjustment provisions.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 09-29-2024, 05:22 PM   #36
trulyvintage
trulyvintage's Avatar
Thumbs up For Tow Vehicles
I put a quart bottle in my 80 gallon
diesel cross tank in my truck bed
occasionally when I fill - it helps
clean the tank and probably the
diesel injectors as well .
1996 Ford F350 XLT 7.3 PSD CC
2WD w/ 4:10 rear diff & E4OD
Jim
trulyvintage is offline   Reply With Quote
Old 10-04-2024, 07:10 PM   #37
TZBrown
I agree on the Marvel carb, performance is fantastic.
Y-Blockhead... any chance those Marvel stickers might be available?
I really like those
TZBrown is offline   Reply With Quote
Old 10-05-2024, 06:37 PM   #38
Jeff in BC
Jeff in BC's Avatar
Here's a picture of the remains of an original Marvel decal.
Jeff
Jeff in BC is offline   Reply With Quote
Old 10-06-2024, 01:17 PM   #39
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I have been running my Marvel for about 8 years.
I drove my A to our next town with the marvel. The drive is a steady 6 mile uphill run. My A screamed up the hill with the Marvel doing 55 in overdrive.
I took the same drive with a brand new rebuilt Zenith. My A bogged down to 50 and I had to take the A out of overdrive to make the hill.
Conclusion: The Marvel is a better carb than the Zenith on my A.
JMO
Dick M is offline   Reply With Quote
Old 10-06-2024, 01:56 PM   #40
GMCPASO
GMCPASO's Avatar
I'm in. Have rebuilt a few and installed a few. One on the engine and one under the seat tuned to my car. Fun to offer a trial to someone that has not got theirs carb working, what ever it is, and see their smiles.
Paul H
GMCPASO is offline   Reply With Quote
