#21 | |
The thing is, it is today and now. Follow NeilinCA's $4K 5 window build thread on the HAMB. If you think the motor is nice, wait until you see the rest of car and chassis. |
#22 |
But a lot of the chrome on the engine, transmission and chassis is old chrome, parts that I found at swapmeets, etc already plated. I wouldn't and couldn't set out to do this today with all fresh plating.
#23 |
Ah, right and good point. How much of the build would you say is new chrome?
#24 | |
Engine: Old Chrome - Starter, Generator, Idler assembly, fan, 97 carbs, air cleaners, fuel pump, fuel pump stand, oil filter housing New Chrome - Water pumps, timing cover, motor mounts, plug wire conduits, oil pan, coil, headers Transmission: Old Chrome - Transmission case, Shift tower, shift lever, knob, clutch release arm New Chrome - Rear mount, emergency brake handle and bracket Front Suspension: Old Chrome - Axle, wishbone, perches, spring, u-bolts and pad, backing plates, tie rod ends, steering box, pitman arm New Chrome - Spindles, shackles, shock arms, dogbones, draglink, tierod Rear Suspension: Old Chrome - Spring, u-bolts New Chrome - Axle bells, banjo, radius rods, torque tube, backing plates, shackles, shock links Misc: Old Chrome - Grille insert, BLC headlights, front spreader bar, hood latches, high crown baby moon hubcaps New Chrome - Column tube, battery box, pedal assembly, throttle pedal, garnish moldings, windshield frame |
#25 |
#26 | |
#27 |
The Old Chrome Coupe "SHOW TIME"
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV.
#28 |
very impressive !
#29 |
as good as it gets.
#30 |
Reminds me of looking through old 1960s Hot Rod magazines with everything chromed.
Ah, the good ole' days!
Matt 24:36-41 |
#31 |
Nice! Ya gotta share your plater with us!
