Old 06-18-2023, 02:27 PM   #21
Fordestes
Default Re: Woven vs molded linings for cast iron drums
Anybody used the made in Germany molded linings that are sold by sniders? I am changing to cast iron drums and am thinking about trying them, any opinions on those particular linings ?
Fordestes is offline   Reply With Quote
Old 06-18-2023, 02:51 PM   #22
alexiskai
alexiskai's Avatar
Originally Posted by ModelA29 View Post
I wonder if the removal of asbestos from brakes has had an effect of their stopping distance or fade resistance.
Asbestos-alternative brake linings are more expensive but have equivalent or better performance.
Old 06-19-2023, 04:27 PM   #23
nkaminar
nkaminar's Avatar
Hey Alex, What is the source for the asbestos alternative brake linings?
Old 06-19-2023, 04:52 PM   #24
Y-Blockhead
Y-Blockhead's Avatar
I have Snyder's molded brake linings on my Town Sedan. I didn't know they were made in Germany until I read your post. I believe they work better than the woven linings I had on the car previously. I have Cast Iron drums.
I did notice they squeal a little when cold but that goes away after a couple of stops. And they smell.
Old 06-19-2023, 07:58 PM   #25
updraught
updraught's Avatar
Asbestos use has been banned here but not in the US it seems, tho unlikely to be used now.
https://www.theasbestosinstitute.com...in-brake-pads/
You never know where it will turn up.
https://www.abc.net.au/news/2021-11-...ials/100604278
updraught is offline   Reply With Quote
Old 06-20-2023, 06:36 AM   #26
nkaminar
nkaminar's Avatar
Don't breath asbestos dust. When you die it will take 3 days to cremate you.
Old 06-20-2023, 09:42 AM   #27
mhsprecher
mhsprecher's Avatar
I appreciate all the comments. I replaced the rear brake shows with woven linings I got from a fellow club member. We shall see. I took it on a test drive and everything seemed fine except that my left rear shoes are too tight in the drum. Quite the learning experience for me. As much as I love the Les Andrew red book, his section on replacing rear brakes shoes is not very complete.
One related question: The red book says that when you use the brake centering tool to bend the tabs on the shoes if they are not centered. What tabs is he talking about? I didn't see them.
1910 Model T Touring
1924 Model T Coupe
1928 Model A Roadster
1930 Model A Town Sedan
1939 Deluxe Fordor
1945 pickup
1951 Custom convertible
mhsprecher is offline   Reply With Quote
Old 06-20-2023, 12:04 PM   #28
Y-Blockhead
I believe he is referring to bending the roller tracks to center the shoes, not the bending the shoes themselves.
Old 06-22-2023, 08:25 AM   #29
Ayers1
Ayers1's Avatar
I remember years ago they made a cast iron ring that pressed on the steel drums. They supposedly made a huge difference. Are they still available or is cast drums the only option? Just curious.
Ayers1 is offline   Reply With Quote
Old 06-22-2023, 08:38 AM   #30
Y-Blockhead
Yes, the brake drum reinforcing band for the steel drums are still available from some vendors.
Old 06-22-2023, 08:54 AM   #31
Ayers1
Ayers1's Avatar
Thanks!
Old 07-02-2023, 08:41 PM   #32
mhsprecher
mhsprecher's Avatar
Update: I picked up some woven linings from a Model A club friend for my back brakes. I got everything done, but my driver's side drum was too tight, so I couldn't take my car to the show the next day. I disassembled the brakes and sanded the linings some. I also adjusted the brake rod and added an extra axle shim as I could see that the linings were rubbing agains the new drums. That seemed to do the trick and on the short test drive, I have lots of brake pedal and good stopping. I will drive it some more tomorrow and I should be good to go for the parade on July 4.
1924 Model T Coupe
1939 Deluxe Fordor
1945 pickup
Old 07-26-2023, 03:52 PM   #33
dmar836
Update? This is a job I have coming up.
D
dmar836 is offline   Reply With Quote
Old 07-26-2023, 04:06 PM   #34
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
In late 1931, ford introduced cast iron drums for front wheels only. I have never heard any comments on them recommending anything other than regular woven linings
Richard in Anaheim CA is offline   Reply With Quote
Old 07-26-2023, 10:02 PM   #35
Synchro909
Synchro909's Avatar
I scratched my head over this question a while ago. I decided to buy the drums already mounted on hubs from Randy Gross. He advised woven linings in cast drums. I took him at his word.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 07-26-2023, 11:38 PM   #36
Y-Blockhead
Really? The brake shoes Randy sells are Molded and Bonded.
Old 07-27-2023, 04:10 AM   #37
old31
Originally Posted by nkaminar View Post
Paul, I guess that puts me in the 1 percent although my bank account doesn't know that.
For future reference, the coefficient of friction can be measured by putting the sample on a piece of cast iron or steel and raising one end until the sample slips. The coefficient of friction is the tangent of the angle when the sample slips. The amount of weight on the sample does not change the physics or math but more weight may change the coefficient of friction.
Oh my head hurts. Samples, angles, coefficients, weights, slipping, physics, cast iron, steel, tangents.
Old 07-27-2023, 07:42 AM   #38
Mel Gross
All of the brake shoes in our stock and every job that leaves are shop are of a soft composite material and bonded. Both the leading and trailing edge of the shoes are chamfered. We have been using the same material for close to 20 years now with great success.
Mel Gross is offline   Reply With Quote
Old 07-27-2023, 08:07 AM   #39
updraught
updraught's Avatar
My Mintex Brake Service Guide says:
"The most common cause of chatter and groans is the lack of centralisation of the brake shoes due to wear of the shoe support bracket"
It says you can use an over size pin of 0.020 in the rollers of the brake shoe (oversized pins have a depression in the head)
Or
"The worn ears of the shoe support bracket may be bent upward. A small crescent wrench is a handy tool for this"
Old 07-27-2023, 08:44 AM   #40
P.S.
Now, I'm really confused.
P.S. is offline   Reply With Quote
