Old 01-10-2022, 10:34 AM   #21
flatrod
flatrod's Avatar
Default Re: Can you id this ford.
It looks pick up to me too. I thought only the trucks used the horizontally mounted oil filter.
flatrod is offline   Reply With Quote
Old 01-10-2022, 10:48 AM   #22
paetsgone
was not a pickup i recall. thanks to all for pitching in. scott
paetsgone is offline   Reply With Quote
Old 01-10-2022, 11:47 AM   #23
craig
It's a 352 in a 65-66 F100
craig is offline   Reply With Quote
Old 01-10-2022, 11:49 AM   #24
craig
It's a 352 in a 65-66 F100. The angled oil filter, hand choke and flat top valve covers are the indicators
Old 01-10-2022, 12:56 PM   #25
scicala
scicala's Avatar
If the alternator and carb/intake are original...., I believe alternators started in 64 1/2 or '65. The carb appears to be a four barrel 4100 and the style accel pump cover that was used after '64. Definately an FE engine. My Guess is a '65 or '66 Galaxie with a 390, since 352's didn't use a four barrel carb after 1960.
Sal
Old 01-10-2022, 01:00 PM   #26
scicala
scicala's Avatar
Craig,
Good catch on the manual choke. At first look I thought the choke assembly was just missing. Also thought V8 trucks had auto chokes in '66 ? Could be wrong.
Sal
Old 01-10-2022, 01:22 PM   #27
Lanny
Lanny's Avatar
Hey Scott, is there a chance you could go out and snap a picture of'
that vehicles body ?
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 01-10-2022, 01:55 PM   #28
craig
Sal, I've had a '65, '66, and a '67 F100. All were original 352's with manual choke 2100's, alternators and the squared top valve covers. This photo is definitely a pickup from those 3 years. In '68 the pickups got a 360, 2100 with an auto choke and the rounded, Powered by Ford valve covers. I just don't have a picture of any of my old rigs to verify it
Old 01-10-2022, 03:32 PM   #29
scicala
scicala's Avatar
Good info Craig. This engine has a 4100 4 barrel. That's why I'm leaning towards a 390. Chances are the carb and intake have been chaged after all theses years. I don't know if a 390 was ever offered in a truck ?
Sal
Old 01-10-2022, 04:50 PM   #30
KULTULZ
KULTULZ's Avatar
Question Re: Can you id this ford.
Are you sure you are not looking at a 2100?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 01-10-2022, 05:16 PM   #31
craig
Take another look Sal, I can see the rear of the mounting flange, and I can't see anything that looks like the secondary throttle plate activator rod that would be on a 4100
Old 01-10-2022, 05:52 PM   #32
scicala
scicala's Avatar
If you look closely over the top of the choke plate, you can see one of the screws that holds down the rear of the bowl cover for the rear barrels, plus part of the boss for the vacuum passage to the secondary diaphragm.
All I can say is someone must have disabled the rear two barrels by removing the rod that comes from the diaphragm lever.
Actually, after a better look I can see the tip of the sec. diaphragm lever. Not to mention one of the secondary bowl vent tubes sticking up.
Sal
Old 01-10-2022, 06:01 PM   #33
scicala
scicala's Avatar
Pretty sure, since I can see one of the rear screws that hold the bowl cover down on the secondary side.
Sal
Old 01-10-2022, 06:20 PM   #34
5851a
As others have mentioned, those are truck inner fenders. I agree with craig narrowing it down to 65 or 66.
5851a is offline   Reply With Quote
Old 01-11-2022, 12:08 AM   #35
craig
Sal, take a look at this carb. I think the castings at the rear are what you think are screws Whoops, no picture!
Old 01-11-2022, 12:14 AM   #36
craig
https://st.hotrod.com/uploads/sites/...rebuild-02.jpg
Sal, go to this site and you'll see the picture
Old 01-11-2022, 09:51 AM   #37
flatrod
flatrod's Avatar
I thought it looked like a 2100 as well. As I remember only the 289 HiPo's were the only 4100 that have manual chokes. And its not a 289! Hard to tell what the carb is for sure.
Old 01-11-2022, 10:54 AM   #38
rotorwrench
rotorwrench's Avatar
Friends & family owned Galaxies, LTD, and Mercury Monterey cars in 65 & 66 and I spent time working on them. They don't look like the one in the photo for sure. My Pop had a 66 Ford F100 that looked a lot like what's in the photo. They had the twin I beam front ends.
Old 01-11-2022, 11:31 AM   #39
scicala
scicala's Avatar
At this point I see arguments for a 2100 and a 4100. Probably doesn't matter at this point as parts can be changed over all those years.
Sal
Old 01-11-2022, 11:56 AM   #40
paetsgone
thanks again. i will return in time and update if anyone is interested. i really don't remember it to be a pickup but i have no memory left.
