Old 07-07-2021, 12:54 PM   #21
JWL
Default Re: KR Wilson spring spreader
I made mine from a top link of a tractor 3-point hitch. Cheap, works great, and easy adapt.
JWL is offline   Reply With Quote
Old 07-07-2021, 01:45 PM   #22
glennpm
glennpm's Avatar
I used a Harbor Freight "Porta-Power" on the 40 rear spring in my 32.
File Type: jpg Jack in center and one on drum to remove shackle 1.jpg (69.3 KB, 321 views)
Last edited by glennpm; 07-10-2021 at 02:00 PM. Reason: change dimension on short chisel end
Old 07-07-2021, 04:17 PM   #23
Lawson Cox
Lawson Cox's Avatar
I owned one with a friend who died. His daughter sold it, not knowing our arrangement. Too expensive to buy another to use just one time. So goes life.
Old 07-07-2021, 07:54 PM   #24
Yoyodyne
Yoyodyne's Avatar
Just FWIW a local rental shop rents a 10 ton portapower for $19 for half a day.
Yoyodyne is offline   Reply With Quote
Old 07-07-2021, 08:14 PM   #25
Lawson Cox
Lawson Cox's Avatar
Not around here, at least not one I can locate. I have found a good spring spreader that I can borrow from a friend of a friend. Picking it up in the morning.
Thanks, everybody. I'll let y'all know how it goes.
Old 07-07-2021, 08:37 PM   #26
v8fordman
v8fordman's Avatar
Originally Posted by Terry,OH View Post
The K R Wilson spreader as shown in post #4 above will only do the rear spring due to it's over all length. K R W had a associated tool that used in conjunction with their spreader would do the front spring.
This piece you speak of is an attachment to the pictured spreader and a VERY rare piece. I have a KRW spreader and have borrowed that piece from a friend to do fronts. I even tried to get a machine shop to mill one for me, but it is complicated and therefore too expensive to do a one off. Always wondered if there were enough spreaders left to create enough interest to have some made?
v8fordman is online now   Reply With Quote
Old 07-07-2021, 08:54 PM   #27
Yoyodyne
Yoyodyne's Avatar
Do you have a photo of the attachment?
Old 07-08-2021, 08:04 AM   #28
1931 flamingo
1931 flamingo's Avatar
Lawson.....................BE CAREFUL ! ! !
Paul in CT
Old 07-08-2021, 08:07 PM   #29
v8fordman
v8fordman's Avatar
I will have to make a picture of it, but it is a unique piece.
Old 07-08-2021, 08:18 PM   #30
Lawson Cox
Lawson Cox's Avatar
Paul in CT
ALWAYS. Too overly cautious at times methinks.
Query: At what point do you stop "spreading" the spring? If you spread it far enough to move the shackle link, does not that remove the pressure on the link? Does spreading the spring farther somehow reduce the pressure on the link, making it easier to remove? Inquiring minds want to know.
Old 07-08-2021, 10:16 PM   #31
bbrocksr
Yes, if you spread it far enough to change the angle of the shackle the pressure is reduced. Spreading it farther won,t help much.
Bill
bbrocksr is offline   Reply With Quote
Old 07-09-2021, 09:10 AM   #32
Yoyodyne
Yoyodyne's Avatar
At the risk of being Mr Obvious, is this to be done in a vehicle or out of the vehicle? If the spring is in a car/truck, you can support the ends of the spring with blocks and/or jacks to take the weight off the shackles and remove them that way. And yes, just slight movement indicates the pressure is off.
This can be safer than a spring spreader, as long as the car is supported safely.
Old 07-09-2021, 10:12 AM   #33
19Fordy
19Fordy's Avatar
Yoyodyne: Seems pretty risky to me.
Old 07-09-2021, 10:31 AM   #34
Yoyodyne
Yoyodyne's Avatar
It can be, it's best to have help. I've done it plenty on As and Ts by myself, with just wood blocks between the axle and spring, V8s need more outside support.
Old 07-09-2021, 03:17 PM   #35
Lawson Cox
Lawson Cox's Avatar
Thanks, bbrocksr, Yoyodyne, and 19Fordy for the comments. I was able to borrow a Litchfield spreader, but unfortunately, it was not a complete spreader as it was missing the shorter piece and therefore about 1/8" too long, and wouldn't work for me. I'm gonna just go ahead and spring for (no pun intended) for a new Porta Power from Harbour Freight and let my heirs figure out what to do with it. LOL
Y'all have really been a big help with this, and I really appreciate your putting up with me again. Thanks.
Until the next problem arises, I'll still be lurking hereabouts.
Lawson
Old 07-09-2021, 03:30 PM   #36
40cpe
40cpe's Avatar
A few years ago I bought a 4-ton ram from Harbor freight. I got it on sale for $100. I have used it several times on the springs on my '38. When Lawson started this thread I was going to recommend this too, but I looked on line and only saw the 10-ton version for considerably more.
40cpe is offline   Reply With Quote
Old 07-09-2021, 04:51 PM   #37
v8fordman
v8fordman's Avatar
Here are a couple of pictures of the attachment that allows you to remove (or install) the front spring using a KRW spring spreader. Notice how it attaches which causes the overall length of the piece reaching the spring to become reduced. This works very well as most KRW tools do. As mentioned earlier, this is a VERY rare attachment for the KRW spring spreader. I've only seen two in my life.
Old 07-09-2021, 05:11 PM   #38
glennpm
glennpm's Avatar
Hi Lawson,
If you are only 1/8" too long, you could use your floor jack under the spring end, jack it a little and slip the spreader in.
Not that with the Harbor Freight unit, it comes with only one "chisel" end. I made another from pipe as you can see in my post #22.
Glenn
Old 07-09-2021, 05:53 PM   #39
Yoyodyne
Yoyodyne's Avatar
I think I understand. Yes, it would be tough to fabricate to replace that casting, without spending huge time on it. Thanks for the photos.
Old 07-09-2021, 08:48 PM   #40
Kube
Super Moderator
Kube's Avatar
Yikes! I've done a few things and amazingly walked away unharmed. Read: young and dumb.
I would NEVER remove a spring the way you suggest.
