Old 03-02-2021, 07:33 PM   #21
cluck
cluck's Avatar
Default Re: two tooth steering box lubrication
having some maintenance done on my car and they noticed the steering gear box was low on oil so they topped it off with oil. now it is probably about 1/2 oil and 1/2 grease. One of the comments I had seemed to think a mixture would be ok. will let you know when the "A" comes home
cluck is offline   Reply With Quote
Old 03-03-2021, 12:06 PM   #22
Patrick L.
Patrick L.'s Avatar
A mix of both grease and oil ? I think thats probably what most have.
Old 03-03-2021, 06:13 PM   #23
hudson32700
Mister Moose: United Ag and Turf (John Deere dealer) They should have it in stock, about $4.00 a tube.
hudson32700 is offline   Reply With Quote
Old 03-03-2021, 10:42 PM   #24
Mister Moose
Mister Moose's Avatar
None nearby, I was hoping for someone to pitch in for the effort if I took the time to chase down Tractor Supply, also not nearby.
Mister Moose is offline   Reply With Quote
Old 03-04-2021, 11:19 AM   #25
Magoo2
Barkhamstead,Ct has a tractor supply. Not sure how far that is from you. I’m using their 00 grease seems to work fine. Warm it up before installing.
Magoo2 is offline   Reply With Quote
