#21 |
It looks like a nice tidy job. The calliper is better looking than the type in the commercially available kits, in my opinion. I would agree on the marketing. If no one else was making them, it might make sense, but not with relatively cheap kits freely available.
Mart. |
#22 |
Thanks Mart.
The competition from cheap kits was an issue. |
#23 |
Since you are not going to market them would you post a parts list if someone wants to do this on their own? I personally like drums so this isn't for me, but the ability to retain stock track width and wheels may be a big enough draw for someone else to give it a try.
#24 |
Just curious.... have any of you tested to see if a 1 inch bore master cylinder actually gives redundancy in your brake system?
Many years back in converted my f1 to dual reservoir and found that when I cracked a bleeder on the front or on the rear. There was not enough travel to effectively brake..... basically making the dual system kinda pointless. So I found a master with an inch and an 1/8 bore that that worked well AND gave redundancy. When I built my 4x4 f1 I used disc's up front and found tge some thing again....a 1 inch bore disc/drum master didn't move enough fluid to provide redundancy. Do I had to go to an 1 and an 1/8 bore to make it right.
23 t touring 25 tt huckster 30 coupe 30 coupe (traditional hotrod) 31 pickup 38 standard 42 gpw (ford army jeep) 48 f-1 52 f-1 52 f-1 4x4 55 chevy 55 m38a1 56 Victoria 68 bronco 70 land rover 72 club wagon |
#25 | |
Those are just a few reasons that I'm going to decline. |
#26 | |
a larger reservoir size would be more key (in my opinion) to having a positive outcome from a leak in a brake circuit. To check the safety benefits of a dual chamber master you would have to screw pressure gauges onto wheel cylinders and then simulate the leak in the opposite circuit. |
