#21 |
Has anyone actually done a pair of comparison oil samples or is that just speculation?
'54 Skyliner. As close to original as I could restore it to. |
#22 |
Actually I did, for mine. I have an original oil bath and the one I converted to a (paper) K&N. then drove the car over the same road, same speeds, and I found that the one with the K&N in it, gave me better performance. That could just be me or just my car.
#23 | ||
An oil bath filter assy diverts air intake flow so as to have heavy particulate fall out of suspension and be caught/absorbed by the oil bath. The problem with a K&N type is on an EFI, the oil may foul the MAF SENSOR or leave an oily buildup on the intake tract and throttle body. The only way I know to compare air flow/intake is to put each style ACL on a carb and flow bench. Same with a HP OIL FILTER. The filtering media is less restrictive to allow full oil pressure and flow. The oil filter on a HP engine is changed much more frequently according to it's build. Quote:
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) Last edited by KULTULZ; 07-13-2024 at 11:39 AM. |
#24 | |
I belong to a diesel engine forum where the theory came up that paper filters are better than oiled cloth filters. My Dodge/Cummins is on a 30,000 mile oil drain schedule. I sample every 15,000 miles. My silicon PPM count is lower than any paper filter sample that has been posted, and they are all less than 10,000 mile samples. It is true that some oiled filters contaminate MAF sensors and so on. They are those whose owners believe if a little oil is good, more is better. If I over oil mine, which I did once, the residue shows up on the intake blades of my turbocharger. I doubt that anyone of us drives their classic enough to even consider extended drain cycles and it is highly unlikely that there are many, if any, analysis data sheets. I, for one, modified my air cleaner to accept a paper filter. I do plan to send in a sample after I've put some miles on the engine. My focus is wear metals, water and coolant.
#25 |
And while still in b!tching mode -
![]() Hope she never hiccups or backfires as the engine will most likely get an oil bath and if used on a HP engine, WOT is going to suck on the actual ACL oil level. If you read the SERVICE DECAL/SERVICE INSTRUCTIONS closely, it tells you to check the oil level frequently as not all suspended oil in the element drains back into the sump. One reason INSTR call for different weight oils for different outside ambient temperatures. How long would you have to soak the actual filtering section to actually have it come clean (if it ever does)? How long to allow it to air-dry before re-installing? Few liken this to a SPIN-ON OIL FILTER upgrade.
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) |
#26 |
