Old 03-12-2021, 12:16 PM   #21
1948F-1Pickup
1948F-1Pickup's Avatar
Default Re: Fan Belt Tension Adjuster....
I have one of those "fan belt fulcrums' on my truck..... takes about 50% of
the fool-around out of setting the belt tension.
1948F-1Pickup is offline   Reply With Quote
Old 03-12-2021, 12:49 PM   #22
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by 19Fordy View Post
Did more searching. Can anyone post a photo or explain how the tool shown in Post #41 works?
https://www.fordbarn.com/forum/showt...t=55015&page=3
Maybe a little enlightenment.
Old 03-12-2021, 03:37 PM   #23
19Fordy
19Fordy's Avatar
Thanks 51 Merc- CT for posting that excellent photo. Just curious, that black flathead has some unusual pulleys, mounts and oil pan. Where was that engine used?
Old 03-12-2021, 03:41 PM   #24
Russ/40
Russ/40's Avatar
19Fordy, the tool to which you refer in post 41, the link to older tool posts is actually my tool. Surely the most complex of the tool suggested, but no more difficult to use. Sets up in seconds and gives easy adjustment control.
The tool anchors on the bolt mounting stud for the generator through the top with a deep socket. It then clamps the generator mount foot. By simply cranking the nut on the bottom you are raising the generator effortlessly.
So you put the tool on, loosen the stud bolt and crank the bottom nut. When the desired tension is reached, you tighten the generator mount nut, pull the socket out of the top and remove the tool.
more photos below: For Helmit style distributors, you need to remove the coil. For crabs you do not need to remove the coil.
Russ/40 is offline   Reply With Quote
Old 03-12-2021, 03:48 PM   #25
19Fordy
19Fordy's Avatar
Russ, That is a very slick tool. It has that KR WILSON persona. Well done.
I would like to make one.
What did you use to make the U shaped channel bottom piece? Was it adapted from another piece of material?
Old 03-12-2021, 04:56 PM   #26
51 MERC-CT
51 MERC-CT's Avatar
It's a French flathead either military or commercial with water pumps that are unusual with something mounted to the pump on the drivers side (maybe gen/alternator?)
Also the timing cover has a built in distributor lock down screw and cam end play adjusting screw.
Old 03-12-2021, 05:17 PM   #27
Russ/40
Russ/40's Avatar
It was one of those days when you ask yourself what am I going to do today. There had been a bit of talk about how difficult it can be bending over forward and trying to pull up the gen and get things buttoned down securely. I decided I had only one purpose that day, and it was to think through an elegant but simple way to do the job. It was really fun as I worked my way through ideas, and solving obsticals.
The bottom clamp for the generator mount is made from part of a piece of angle iron. The "V" like piece is shaped to give max height lift to the gen and the tab in the middle of the V is to engage the slot the mount has to allow adjustment. The two pins help stabilize the bottom bracket limiting any side movement. This is what makes it so easy to get the tool properly seated eliminating a lot of fidgeting in the process. The lower foot behind the pins also adds to the stability of the tool. With experience you could actually do the job with the tool and use one hand.
I could CNC them in quantity but they would probably have to go for $50.
Old 03-12-2021, 06:11 PM   #28
19Fordy
19Fordy's Avatar
Thank you Russ for the reply. There might be a few folks willing to pay the $50 but not enough to justify the manufacturing cost. Manufacturing is expensive.
Old 03-12-2021, 07:24 PM   #29
Jeff/Illinois
Jeff/Illinois's Avatar
I was going to suggest that Russ make some up and sell them thru the parts vendors like Joe's in Massachusetts! This is slick, well done man!
Jeff/Illinois is offline   Reply With Quote
Old 03-12-2021, 10:42 PM   #30
tubman
tubman's Avatar
I will tell you from experience that making things for these old engines has to be a labor of love. You will not make any money doing it. That being said, I would do it again in a heartbeat.
tubman is online now   Reply With Quote
Old 03-12-2021, 11:22 PM   #31
Tinker
Tinker's Avatar
still pretty cool and probably the most precise method/tool I've seen for belt adjustment.
Old thread for stuff like this. Lot of great ideas from inventive people.
https://www.fordbarn.com/forum/showthread.php?t=56112
Old 03-12-2021, 11:56 PM   #32
petehoovie
petehoovie's Avatar
Originally Posted by Tinker View Post
Old thread for stuff like this. Lot of great ideas from inventive people. https://www.fordbarn.com/forum/showthread.php?t=56112.
Old 03-13-2021, 09:45 AM   #33
19Fordy
19Fordy's Avatar
Here is another method.
Cover the blade of a long screwdriver (to protect the paint) and place the point of the screwdriver in the little valley behind the distributor and block and aligned so that the screwdriver blade is under the appropriate bracket. Then pull up on the screwdriver handle and snug up the bolts.
Old 03-13-2021, 12:02 PM   #34
Russ/40
Russ/40's Avatar
True! You never need to hold any tension anywhere while you check the belt tension. Probably the best feature for us "older gents".
Old 03-13-2021, 12:44 PM   #35
Jeff/Illinois
Well said and our backs will thank us for it!!
Old 03-14-2021, 10:32 AM   #36
Terry,OH
Terry,OH's Avatar
Russ: Great idea for a tool!
Old 03-14-2021, 10:59 AM   #37
JSeery
JSeery's Avatar
I like it.
Old 03-14-2021, 01:22 PM   #38
oldford2
oldford2's Avatar
Any pics of tensioners/fulcrums for the 59 block where the wire looms are in the way? Thanks
John
oldford2 is offline   Reply With Quote
Old 03-14-2021, 07:32 PM   #39
3twinridges
3twinridges's Avatar
We had good luck using an engine hoist and a strap to set the tension on the generator and fan belt. I think I picked that up over on FTE.
JB
3twinridges is offline   Reply With Quote
Old 03-14-2021, 08:09 PM   #40
VeryTangled
VeryTangled's Avatar
JB
This brought a smile to my face, okay I chuckled!
This thread has gone all over the place, but not in a bad way.
But we've gone from a couple of pieces of cardboard, a bolt and a coupling, to an engine hoist.
-Jeff H
Have you thought about supporting the Early Ford V-8 Foundation Museum?
VeryTangled is offline   Reply With Quote
