Old 10-19-2020, 11:36 AM   #1
1936 ford pickup
Default Fan Belt Tension Adjuster....
Hello to ALL....
I have a '36 Ford pickup with an alternator and wanted to replace the Fan Belt with new. I utilized a 7/8" x 1 1/4" long Coupling Nut (with 1/2-13 NC internal thread) and a 1/2-13 NC x 1 1/4" long Hex Head Bolt. I used round cardboard cut-outs under the Coupling Nut and above the Hex Head Bolt to make sure I did not scratch the paint on the intake manifold and bottom of the Alternator.
Slowly turning the Hex Head Bolt counter-clockwise put tension on the Fan Belt.
Worked perfect so I wanted to share and hope it may help someone else out there. Just curious as to what others out there do for Fan Belt tensioning.
Bruce in Ca.
1936 ford pickup is offline   Reply With Quote
Old 10-19-2020, 11:55 AM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Fan Belt Tension Adjuster....
Broom handle. 8^) Jack E/NJ
Old 10-19-2020, 12:48 PM   #3
51 MERC-CT
51 MERC-CT's Avatar
double post
Old 10-19-2020, 12:50 PM   #4
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by 1936 ford pickup View Post
Hello to ALL....
Bruce in Ca.
Same thing over 50 years ago.( Necessity is the mother of invention )
Old 10-19-2020, 09:59 PM   #5
GB SISSON
GB SISSON's Avatar
I use a 2x4 with a long diagonal cut on one end. I really like this coupling nut thing and can't wait to copy it. Thank you Bruce!
GB SISSON is online now   Reply With Quote
Old 10-20-2020, 11:36 AM   #6
Jeff/Illinois
Jeff/Illinois's Avatar
Good idea. It is tricky to tighten the fan belt on these motors, at least I always thought so.
We have a '36 PU too, anxious to see yours when done please post pics
Old 10-20-2020, 12:23 PM   #7
38bill
38bill's Avatar
Just don't get them so tight that they screw up the generator.
38bill is offline   Reply With Quote
Old 03-11-2021, 08:58 PM   #8
Jeff/Illinois
38Bill...
I was in the garage today and my fan belt on the '36 PU had about 1 and 1/8th inch deflection at the half way point of the belt.
I snugged it up, knowing about not being too tight, and now it has just shy of an inch maybe 7/8ths inch.
It seemed before that my ammeter was bouncing just a wee bit at idle and I was concerned the belt was slipping a tad bit.
I was brought up to make sure they were about 1 inch of deflection.
Is this too tight now??
Old 03-11-2021, 09:39 PM   #9
VeryTangled
VeryTangled's Avatar
Where the heck is that thread about cool tools that people made or use?
It's from years ago from what I remember. A V-8'er had grafted a wrench to a prying point to help lift that stubborn genny with a lever applied to it. JM35's super engineered steering and rear hub pullers were in there too!
I love your idea because adjusting that belt without getting a little medieval is a challenge.
Just recall your deflection at midpoint. That belt don't have to be TIGHT to spin the pumps and power maker. But too tight will jack their shafts up eventually.
-Jeff H
Old 03-11-2021, 09:51 PM   #10
Scotty's 52 F3
Scotty's 52 F3's Avatar
I use a big bar but, I like this better. Thanks for posting.
Scotty's 52 F3 is offline   Reply With Quote
Old 03-11-2021, 10:46 PM   #11
Ross F-1
Ross F-1's Avatar
This is the most elegant tool I've seen, I have it saved as being "1950FordF1"s. (from FTE I suspect) I tried to make one like it but was not successful.
Vergil on here posted the "fulcrum" that bolts onto the WP bolt. Works well but really needs another bolt to keep it from rotating.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 03-11-2021, 11:17 PM   #12
tubman
tubman's Avatar
Here are a couple of pictures of "Vergil's Tool" :
Old 03-12-2021, 10:04 AM   #13
19Fordy
19Fordy's Avatar
Mr. tubman, Any chance of reposting those photos to make them larger?
Thanks.
I found it:
https://www.jalopyjournal.com/forum/...n-belt.971007/
Old 03-12-2021, 10:04 AM   #14
19Fordy
19Fordy's Avatar
Thanks.
Sorry for the double post.
Old 03-12-2021, 10:26 AM   #15
tubman
tubman's Avatar
Thanks.
I did blow them up, but wasn't satisfied with the resolution. Here is what I have. I hope it's satisfactory. (Click the "thumbnails.)
Old 03-12-2021, 10:31 AM   #16
19Fordy
19Fordy's Avatar
Did more searching. Can anyone post a photo or explain how the tool shown in Post #41 works?
https://www.fordbarn.com/forum/showt...t=55015&page=3
Old 03-12-2021, 10:41 AM   #17
19Fordy
19Fordy's Avatar
Thanks tubman, After I posted , I did a little more searching and found larger version of your follow up.
Thanks for responding.
Old 03-12-2021, 10:50 AM   #18
Jeff/Illinois
Now that fulcrum point looks like a good idea too.
Thanks.
Old 03-12-2021, 10:52 AM   #19
Kube
Super Moderator
Kube's Avatar
Hello to ALL....
Bruce in Ca.
I had made a scissors type tool where I am able to place the non-adjustable ends between the generator and valve chamber cover. The adjustable end of my tool is a simple thumb screw. Turning it lifts the generator. I pretty much copied the basic concept from an old brake caliper piston retracting tool.
It appears your fan belt is not correct - too long. Factory fitment had a much smaller "open space" between the generator and chamber cover.
Old 03-12-2021, 11:04 AM   #20
Jeff/Illinois
Kube I think you are right, as I'm almost out of adjustment the gennie sits kind of high.
This is the belt that was on the truck when I bought it, never gave it much thought. I'll check into it. All I ever did was look for splitting on the 'V' showing time to replace.
