Old 07-25-2020, 08:10 PM   #21
koates
Default Re: Gets warm and quits running?
Originally Posted by Karl View Post
Two where new condensers from one of the parts houses that I had brought as spares and one was a Mallory one recommended on here somewhere -It was brought online and judging by the packaging was NOS -Karl
Karl, thanks, but I really wanted to know the part numbers of those condensers, especially the Mallory one. Regards, Kevin.
koates is offline   Reply With Quote
Old 07-26-2020, 12:37 PM   #22
1948F-1Pickup
1948F-1Pickup's Avatar
Originally Posted by deuce_roadster View Post
If using a stock type coil, send it to Skip anyway, even if the current problem is the condenser. I always liked Chuck Yeager's quote "Never wait for trouble" (even though it was uttered during a GM parts advertisement!)
I used to work for Delco. Here's one of my favorite t-shirts from back in the day. I was around for some of those shoots with CY. Lives up in Grass Valley CA....
1948F-1Pickup is offline   Reply With Quote
Old 07-26-2020, 06:54 PM   #23
Jeff/Illinois
Jeff/Illinois's Avatar
Originally Posted by Aarongriffey View Post
Skip, the magic dragon.................
Aaron Griffey
Hayward, taxafornia
THAT'S funny!!
Jeff/Illinois is offline   Reply With Quote
Old 10-16-2020, 09:46 AM   #24
Ford46
Ford46's Avatar
Update on this thread. "Cape Man" and I talked last evening, it seems the culprit was actually the ignition switch! The switch was replaced and after various driving situations with no further issues it seems to have cured that ailment. Now the brakes; master cylinder failure, rear wheel cylinder leaking is a whole different story, those have also been repaired and so far so good. I just wanted to let everyone know the final solution and thank everyone for the help.
Ford46 is offline   Reply With Quote
Old 10-16-2020, 12:13 PM   #25
RKS.PA
RKS.PA's Avatar
Hard to imagine how the ignition switch could be related to heat?? A short that failed when after being on for a while that diminished when turned off and allowed to cool down??? New one on me and hope the fix is permanent!
RKS.PA is offline   Reply With Quote
Old 10-16-2020, 02:22 PM   #26
AnthonyG
AnthonyG's Avatar
Glad its running but agree I never heard of an ignition switch that consistently waited waited till engine warm to quit running. Usually first bump did it. I do agree common issue usually is the condenser or coil.
I know ill get negative comments but JMO onthe condenser/coil prob, as long as ur not an originalist, condenser and points R eliminated & very reliable w a quality electronic distributor & r available as replacement for a '47 AB engine. Also allows for elimination of old style coil and uses a modern external V8 coil 6 or 12 volt replacement also very reliable if a quality Mfgr. https://www.summitracing.com/parts/m...yABEgJ8a_D_BwE
Nomad
AnthonyG is offline   Reply With Quote
Old 10-17-2020, 04:34 PM   #27
Ford46
Ford46's Avatar
It seemed that the car ran for awhile and perhaps it was a bump or a hill or whatever that made the ignition switch act up. Unless it was something severe it was a coincidence that as soon as it seemed to get warmed up and running the issue happened, the car never got far from home. I had the same reaction as most of you. The standard parts were changed thinking those same old issues and it kept happening, fortunately he kept checking and finally found the culprit..... and it was ignition!!!!
