Old 02-27-2019, 05:02 PM   #21
arnhemmer
Default Re: Alternative to anti-freeze to stop corrosion
50 % antifreeze for me, no problems with gaskets since rebuild, (15000 miles.)
arnhemmer is offline   Reply With Quote
Old 02-27-2019, 05:11 PM   #22
Shorty
The key is to start with a clean cooling system including the engine. If nothing else, run distilled water with your choice of cooling system additive. For many years I have used Prestone in my Model A and my daily driver. The antifreeze contains antirust and lubricant. Prestone also makes just the additive if you don't want to run any type of coolant.
Shorty is offline   Reply With Quote
Old 02-27-2019, 06:22 PM   #23
ModelAMike1930
ModelAMike1930's Avatar
I use antifreeze in all of my vehicles its cheap and available everywhere.. I have never had a problem. I have been driving since 1953.
ModelAMike1930 is offline   Reply With Quote
Old 02-28-2019, 09:10 AM   #24
30 Closed Cab PU
Perhaps wildcat is thinking of the GM/Dex-cool issues?
https://www.consumeraffairs.com/news...m_dexcool.html
Most recommend the older "green" antifreeze which is the tried and true coolant for As. Green will not harm A radiators, hoses, head gaskets, waterpumps, etc.
30 Closed Cab PU is offline   Reply With Quote
Old 02-28-2019, 09:48 AM   #25
Smooth_One
Smooth_One's Avatar
I use Royal Purple Ice. 50/50 with green coolant and distilled water. Works great for me!
http://www.royalpurple.com/product/p...tem-optimizer/
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 02-28-2019, 09:50 AM   #26
Smooth_One
Smooth_One's Avatar
A lot of your Water pump builders will want you to run a coolant instead of just plain water for lubrication.
Just my opinion of course but I would run 50/50.
Isaiah B.
Old 02-28-2019, 11:20 AM   #27
31Abone
31Abone's Avatar
How about using cutting oil ?
31Abone is offline   Reply With Quote
Old 02-28-2019, 11:32 AM   #28
Smooth_One
Smooth_One's Avatar
I think that's what a few guys already said they are using.
Isaiah B.
Old 02-28-2019, 12:28 PM   #29
MAG
MAG's Avatar
Agree with Posts 15, 18,19 and 20. Been using Prestone LoTox and Sierra antifreeze for years in all three of my Model A's with no gasket leakage or foaming.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 02-28-2019, 02:49 PM   #30
denniskliesen
denniskliesen's Avatar
I’ve tried water wetter twice with distilled water and twice ended up draining it after it rusted. This last time I flushed a couple times and put in some evaporust for cooling system flushing for a few days. Refilled with distilled water and antifreeze. Problems now gone.
denniskliesen is offline   Reply With Quote
