Old 01-20-2019, 12:44 PM   #21
Branded
Branded's Avatar
Default Re: Dual master cylinder f100 brakes
Originally Posted by 5851a View Post
That's a pretty cool master cylinder with the brake lamp switch in the bottom. Would come in handy for later swaps too that used the same switch.
Here’s the AMC/Jeep master cylinder for drum drum applications
https://www.ebay.com/itm/Brake-Maste...sAAOSwtVdbliit
Branded is offline   Reply With Quote
Old 01-20-2019, 01:11 PM   #22
Newc
Newc's Avatar
Good posts; I found that the '62/3 Cadillac dual drum/drum used the same large brake tubing as the '39/48 Ford. worked for me. Newc
Old 01-20-2019, 01:31 PM   #23
skidmarks
skidmarks's Avatar
Originally Posted by big deuce View Post
Here is a '67 amc vehicle which clearly shows the port near firewall is being used for the front line; split for left and right.
So, can we pretty much agree now to use the port closest to the flange for the front?
skidmarks is offline   Reply With Quote
Old 01-20-2019, 01:33 PM   #24
big deuce
big deuce's Avatar
Going out on a limb, that's how I will plumb mine. I have a couple AMC guys I can check with this week.
big deuce is offline   Reply With Quote
Old 01-20-2019, 01:45 PM   #25
40 Deluxe
Originally Posted by Pete F View Post
The larger resivor is for disc brakes because there pistons are bigger and need more fluid
Actually, the size of the pistons doesn't matter, as the system is filled with fluid to begin with, and piston travel is very small. The need for a large reservoir is because disc brakes have no adjustment for wear. As the pads wear, the piston extends further out, but does not retract. So fluid level in the master cylinder goes down. With a small reservoir, the master may go empty before the pads are fully worn (if no one tops it off in the meantime).
Old 01-20-2019, 02:21 PM   #26
Ggmac
If you purchased your master , even name brand , thru Amazon it does not have residuals in it . You can usually tell by looking . Speedway sells a dual with residual valves .
Ggmac is offline   Reply With Quote
Old 01-20-2019, 02:26 PM   #27
V8 Bob
V8 Bob's Avatar
Piston size does mater, and is why disc/drum and most drum/drum masters are not 50/50 in fluid displacement output. The different primary/secondary port fitting sizes prevent the front and rear OE circuits from being switched.
You are correct that caliper pad wear is one reason the disc reservoir is larger than the drum.
V8 Bob is offline   Reply With Quote
Old 01-20-2019, 02:27 PM   #28
big deuce
big deuce's Avatar
Can you post a link of drum/drum master that has built in residuals?
Old 01-20-2019, 02:31 PM   #29
cas3
my 89 diesel dodge has the big tank to the rear, near the flange, and the small tank to the front, which is feeding the rear drum brakes. i know this because it leaks on a rear wheel cyl. need to fill every 3 months, gonna get to it one of these days
Old 01-20-2019, 02:47 PM   #30
V8 Bob
V8 Bob's Avatar
Drum/drum and (drum circuit) disc/drum masters had factory internal residuals up to the early to mid '70s, but that's no guarantee today's rebuilds have them installed. Easy to check at the parts store.
Old 01-20-2019, 03:05 PM   #31
skidmarks
skidmarks's Avatar
So there is a chance the one I got doesnt have the residual valves. How do you tell ?
Mine was made in China for dorman products.
Both ports on this one is 1/2" fine thread.
Old 01-20-2019, 03:31 PM   #32
V8 Bob
V8 Bob's Avatar
GENTLY inserting a small diameter object will detect an internal residual, which is a small spring loaded rubber check valve.
You may have a "generic" master because the OE AMC would have two port thread sizes, not one.
640 × 410Images may be subject to copyright. Learn More
Old 01-20-2019, 03:39 PM   #33
big deuce
big deuce's Avatar
I can stick a piece of TIG wire clear to the centerline of the casting. I assume there is not residuals in mine. If any doubt, I would run 2lb residual valves, one for each wheel cylinder, correct?
Old 01-20-2019, 05:06 PM   #34
V8 Bob
V8 Bob's Avatar
Run one external 10 lb valve close to the master cylinder for each drum axle if none are internal. The 2 lb valve is strictly aftermarket and should only be used for disc axles when the master is below the floor or lower than the calipers.
Old 01-20-2019, 05:17 PM   #35
big deuce
big deuce's Avatar
Aw, yes i had the 2lb and 10lb valves switched in my head. Thanks for the clarification Bob.
Old 01-20-2019, 06:52 PM   #36
Branded
Branded's Avatar
This one does.
Cardone 10-1292
Old 01-20-2019, 07:29 PM   #37
Talkwrench
Talkwrench's Avatar
A word of caution: A dual master cyl. conversion such as this may not work as intended! If pressure is lost front or rear, the pedal will go nearly to the floor before the remaining brakes engage. If total pedal travel is anything less than the OEM application, you will lose all braking and probably crash!
Save your neck and your car by testing your setup. When everything is hooked up and bled, you likely will have good brakes with little pedal travel. But now, open a front bleeder screw and try a panic stop. If the rear wheels don't slide and the pedal goes all the way to the floor, the system failed. Time to re-engineer! Repeat on the rear brakes and the fronts must lock up or again, fail.
Correct. I think a lot of people, just expect it to work because "its a dual setup"
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 01-21-2019, 11:44 AM   #38
skidmarks
skidmarks's Avatar
I checked the Dorman master cylinder that I have and it does not have the residual valve.
The original single circuit 40 ford master cylinder has a check valve in the base of the bore. Does that serve the same purpose of a residual valve?
Old 01-21-2019, 12:28 PM   #39
V8 Bob
V8 Bob's Avatar
Yes.
Old 08-18-2019, 05:01 PM   #40
PetesPonies
PetesPonies's Avatar
I think I know where you are trying to go with this, but what you are saying is not totally true. A large bore, will require more fluid to move a given distance. And hydraulic pressure is created by the ratio of the different bore sizes; MC to WC or caliper.
To me the most alarming thing happening today, is these drum drum vehicles are being used with MC with different size reservoirs and no residual pressure valves. Typically a large/small reservoir on a MC means it is disc/drum. When you see a large reservoir you can count out a residual valve and even the opening for fluid flow will probably be larger. You loose some engineered brake bias.
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
