Old 08-27-2018, 06:20 PM   #21
Synchro909
Synchro909's Avatar
Default Re: Filter GONE!
Originally Posted by Mike Peters View Post
Maybe I'm wrong, but I don't run air filters at all. We never run on gravel roads, so no dust. When you start your car with full choke, gas will drip from the carburetor. With a filter, that gas will accumulate in the filter body. If the engine happens to backfire, it will start that gas on fire. Safety issue.
Huh??? On ANY warm, dry day there will be dust on any road. Henry built the Model A as cheaply as he could. An air cleaner only prolonged the life of the engine, a benefit not realised till well after the car had been sold so not of much benefit to him Adding one would add to his expenses - something he fought hard to avoid.
I ask "If air cleaners are so useless, why does every modern car have one??"Same with oil filter. I agree that the wiere mesh type air "stainer" is near useless. I run a paper element filter mounted on the radiator stays and wouldn't consider going without one. It is very difficult to install any air filter because of the steering column. Very poor design.
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 08-27-2018, 08:05 PM   #22
old31
Like Ernie, I also use the K&N filter and I drilled a couple of very small holes in the bottom in case gas filled up in there.
Old 08-27-2018, 08:25 PM   #23
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Most any wire mesh will stop a flame in it's TRACKS!
Bill Safe
"THE ASSISTANT GURU OF STUFF"
Old 08-27-2018, 11:22 PM   #24
Tom Wesenberg
Tom Wesenberg's Avatar
Coat the wire mess by soaking it in oil and letting it drip, then install it. Oil traps and holds the dirt until you rinse it out in kerosene.
Old 08-28-2018, 09:16 AM   #25
katy
katy's Avatar
Originally Posted by Ernie Vitucci View Post
Good afternoon...K & N makes a filter that will fit on your 'A'. It is much more fire resistant. I did drill a 3/16th drain in mine and it has been working just fine for a number of years...Ernie in Arizona
Got a picture to share? And/or a part #?
Old 08-28-2018, 10:04 AM   #26
Ted Duke
Originally Posted by slammin View Post
That was back when you could get the engine rebuilt for a few hundred dollars. Price having that work done today.
LOL Back when NO one had a few hundred dollars including the wall street tycoons.
Ted Duke is offline   Reply With Quote
Old 08-28-2018, 10:39 AM   #27
160B
160B's Avatar
Here is a photo of the K&N I use on an original air maze.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
Last edited by 160B; 08-28-2018 at 02:59 PM. Reason: Added photo of air filter w/Air Maze on engine
160B is offline   Reply With Quote
Old 08-28-2018, 10:59 AM   #28
CB919ER
CB919ER's Avatar
I don't run a filter, the roads are cleaner today than they were in the 20s
CB919ER is offline   Reply With Quote
Old 08-28-2018, 05:15 PM   #29
old31
i have the exact setup as 160.
Old 08-28-2018, 06:14 PM   #30
Synchro909
Synchro909's Avatar
Thoise things are as useless as flyscreens for a submarine. They CANNOT be fitted here. The steering column is in the way and I'd prefer steering!
Old 08-28-2018, 09:33 PM   #31
160B
160B's Avatar
Not sure what you feel is worthless as a fly screen. This is a K&N air filter installed with an air maze housing, the original screen is not used.
And yes this is not suitable for a RH drive Model A due to the steering box interference.
Last edited by 160B; 08-28-2018 at 09:37 PM. Reason: added comment on screen and RH dr
Old 08-29-2018, 05:43 AM   #32
SAJ
SAJ's Avatar
Here are my K&N filters. RHD car so I fabricated right angle adaptors at full cross section out of sheet metal as shown in the third pic.
Some (most or Many???) say they are ugly. The oil filter certainly is. I think the more upturned one is cheekily cute! They catch a lot of dirt even on tarsealed roads. And I still get the same 22 to 24 mpg (larger imperial gallons) on a trip at 55 to 60 mph.
SAJ IN UK at present
PS I just noticed the glass filter bowl in the second pic is half full of water. I had a faulty tank cap, since fixed!
SAJ is offline   Reply With Quote
Old 08-29-2018, 09:05 AM   #33
BILL WILLIAMSON
Then how come filters in MODERN cars get FILTHY???
Bill W.
Old 08-29-2018, 09:37 AM   #34
Y-Blockhead
Y-Blockhead's Avatar
Bill W.
How come the K&N on my Model A gets FILTHY??? I usually have my engine pans on also. K&N I use. You will have to extend the Air Maze rod.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Originally Posted by SAJ View Post
Here are my K&N filters. Some (most or Many???) say they are ugly. The oil filter certainly is.
If you use a WIX filter they don't show as much as they are painted black. Or paint your white one black or Ford green.
Old 08-29-2018, 10:28 AM   #35
SAJ
SAJ's Avatar
Y-Blockhead, the ones like yours that point down are not as ugly either. I have not found the correct adaptor in NZ so far. Plus I am always in a hurry to fit a new filter and get going. I forget to paint them and wait for them to dry. Plus again a vertical one can be filled right up before running. I can only fill mine about 2/3 full before fitting.
Then again oil pressure registers within seconds of start up on a new filter on my gauge.
When I get back to NZ I will make a concerted effort to find 2 right angle adaptors for my oil filters............maybe.
SAJ in Cornwall UK
Old 08-29-2018, 06:08 PM   #36
Synchro909
Synchro909's Avatar
SAJ, I think vendors sell the adaptor you want. That said, I have grafted in right angled adaptors from other cars before today.
Old 08-30-2018, 12:10 PM   #37
BILL WILLIAMSON
I've seen Argentina cars, with home made plumbing & an Early Ford Oil Bath air cleaner, mounted at the right front of the engine
Bill W.
Old 08-31-2018, 12:29 AM   #38
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
It was tired of being teased by the other Model A's and ran away.
