#21 |
I'm all ears! Waiting to hear about this possibility.
#22 |
Ditto here!
#23 |
Absolutely go for it. I'd love to be the USA road test for a set. The Lincoln setup is just too expensive for a lot of us. My 40 would be my test case. I've been wanting to do something with the brakes for years. Come on Ted, you can do it!
#24 |
Ted>>>I will see what I can do between doing steering boxes>>>
Thanks Ted!!! But how about doing steering boxes between doing Lockheed floaters instead? 8^) Jack E/NJ |
#25 |
Ted,
I have your kit installed and saw a little improvement, but nothing like you show in your videos. I noticed you mentioned that the shoe material needs to be soft. Does that mean the woven fabric material? Thanks, Brad
Brad Williamson |
#26 |
#27 |
Jerry,
What type of material is on your brake shoes? Brad
Brad Williamson |
#28 |
Here's some lining # NA3923 woven .NA3812 grey soft bonded,not sure if theses numbers would mean much to you ,Ted
#29 |
I would be interested in a set for juice brakes as well.
#30 |
I'm very interested in a set for hydraulics
#31 |
If anyone is confused about types of linnig to use try the Model A site on FB ,or search ,whats good for a A is good for a v8 ,Ted
#32 |
Very cool & informative string.
Nomad |
#33 | |
Ted it would seem that there is a lot of interest. For you to return to this project could make a lot of guys happy and safer stopping. I include myself with the people who would like you to take up the task. Phil NZ |
#34 |
Ted, why are the brake linings we should use with the mechanical energizer kit such a mystery. Can you give us the correct mfg. and their part # & where to get? Your direction to the FB Model A site and the search "whats good for a A is good for a v8" didn't find anything?
Thx
Nomad |
#35 |
https://www.jalopyjournal.com/forum/...ersion.387348/
Check this out there is a heap of info on the Hamb on how to convert early Ford brakes to bendix operation |
#36 |
#37 | |
#38 |
#39 |
I looked at the Ham and that's quite a involved fit up I am hoping to do something simpler than that Lincoln set up ,I will put these through the dealers if successful ,this may need to be in the winter for testing ,
Brake linings The lining numbers I have given are good to use but I don't know if these are USA numbers , I will look into it and report back .What's good for a Model A is good for a v8 ,any search on brakes on the A site will give some useful info. Ted |
#40 |
Here's a picture of the linings previously mentioned ,These can be riveted or bonded ,Ted
