Old 07-27-2017, 06:49 PM   #21
Talkwrench
Talkwrench's Avatar
Default Re: I test drove the 32 today Not good
After you have found and cured your problem you will see why its advisable to add a steering damper.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 07-27-2017, 06:50 PM   #22
Tinker
Tinker's Avatar
Could try swapping out the rear tires for the front (if the same size). Free anyways.
Somethings loosey-goosey...
Old 07-27-2017, 07:07 PM   #23
Anteek29
Anteek29's Avatar
I have that occur occasionally in my '29. Steering box needs a rebuild...lots of steering wheel play.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 07-27-2017, 07:15 PM   #24
Newc
Newc's Avatar
Hi all; Bought a Model A on the cheap because of this and found the wishbone pivot loose. Repaired and it was a good car. Newc
Old 07-27-2017, 07:32 PM   #25
Gary in La.
Gary in La.'s Avatar
The first thing I would check is for correct toe in.
Gary in La. is offline   Reply With Quote
Old 07-27-2017, 08:23 PM   #26
Krylon32
My deuce pu has split bones with 37 Hudson steering leading to 32 spindles all with original 32 tie rod ends. I have 6 degrees of caster and 1/8 toe in. I have ran a steering damper from the beginning and it drives perfect at any speed.
Krylon32 is offline   Reply With Quote
Old 07-27-2017, 09:48 PM   #27
Karl Wolf
Karl Wolf's Avatar
My death wobble upon first drive was due to the fact that one of the tires had a bunch of dried mud in it...
I like the (1976 ish) VW Super Beetle front steering damper...
Have a friendly person move the steering wheel from side to side, just 1 to 3 inches.
You're underneath, touch all the joints one by one, both sides of the joint at the same time.. You will find out where there is any slop.
I'm running about 10 degrees castor angle, small toe-in 1/16".
Karl
Karl Wolf is offline   Reply With Quote
Old 07-28-2017, 09:11 AM   #28
ct1932ford
ct1932ford's Avatar
Are you using a dropped axle? Anyway if you do not find the problem put a steering damper on it. You can get one from So-Cal speed shop or off an early VW. I use one on all my cars it will end the problem.
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 07-28-2017, 10:32 AM   #29
trainguy
trainguy's Avatar
My 39 CS had the same problem,I couldn't find the problem without a major remove and replace program. I nstalled a damper,problem gone!
trainguy is offline   Reply With Quote
Old 07-28-2017, 11:34 AM   #30
RalphM
RalphM's Avatar
I am having the same issue with my AV8.
32 frame, split 37 bones, new axle, 7 degrees caster, bias plies.
First time I thought it was just gen bump I hit, our roads are pretty crappy. Second time I started looking for a problem, only thing I could think of was tightening up the drag link ends( ball and spring style).
I thought I had it, but about a month ago at about 35 mph I hit one of those same gaps in the road and it came back with a vengeance. I had to come to a full stop.
I'm still looking for the problem. Whatever you come up with, I'll give it a try.
RalphM is offline   Reply With Quote
Old 07-28-2017, 12:10 PM   #31
JSeery
JSeery's Avatar
Solid axles don't like bumps! Is the steering box tight?
Old 07-28-2017, 12:17 PM   #32
Paul Selfe
Paul Selfe's Avatar
I agree with Gary, had that problem on my roadster going over tar strips that were slightly at angles. Adjusted the toe-in, no more shimmy. Paul Selfe.
Paul Selfe is offline   Reply With Quote
Old 07-28-2017, 06:09 PM   #33
lafarm
lafarm's Avatar
A weak front spring will change the castor, Had a model A same problem replaced front spring problem cured
lafarm is offline   Reply With Quote
Old 07-28-2017, 06:59 PM   #34
V8COOPMAN
V8COOPMAN's Avatar
You know, I had to think about that one for about four seconds, but you're right.......as the chassis altitude decreases (with a weak spring), the rear of the wishbone goes down. BUT..........that INCREASES the caster in a POSITIVE direction.......which ain't a bad thing! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-28-2017, 09:17 PM   #35
JSeery
JSeery's Avatar
The problem may have been more in the shackles than the spring, than might account for the fix in changing the spring. Hard to believe it was a weak spring alone as removing leaves to lower the front (which would weaken the spring) is a common practice.
Old 07-29-2017, 06:52 AM   #36
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
When I had Model A's the problem was in the wishbone ball being loose. I think I use the rubber ball to correct the problem back then. I have not check that as yet. I got a car on the lift so I need to finish it first.
Old Redneck is offline   Reply With Quote
Old 07-29-2017, 07:36 AM   #37
JSeery
JSeery's Avatar
To many cars, not enough time!
Old 07-29-2017, 07:51 AM   #38
willowbilly3
If everything is right, it shouldn't. That being said, my rpu with split bones did it, bad. Mostly when I'd hit something on a diagonal like a bridge seam.Everything was new, alignment done and 7 degrees caster. Steering stabilizer fixed it. Look under any newer vehicle with a solid axle (like Jeep) and you will see one from the factory.
willowbilly3 is offline   Reply With Quote
