Old 02-10-2017, 10:59 PM   #21
RalphM
RalphM's Avatar
Default Re: Removing 8BA oil fill tube
I can see it now, " what in the h*ll are you cooking!"
Been there, done that.
Washing off carb cleaner with hot water in the kitchen sink.
RalphM is offline   Reply With Quote
Old 02-10-2017, 11:07 PM   #22
AnthonyG
AnthonyG's Avatar
I know what you mean about Mom. Mine would have a fit, Let us know how you make out. Good luck.
Nomad
AnthonyG is offline   Reply With Quote
Old 08-30-2017, 06:01 AM   #23
tubman
tubman's Avatar
I'm back after 6 months. During that time, I have soaked it in various penetrants, heated the manifold while I shoved ice down the tube, and tried to twist it out, all to no avail. I finally resorted to cutting it off close to the manifold with a hacksaw, and then using a cutoff wheel on my Dremel to cut through the portion still inside the manifold. I was then able to peel it away from the manifold with a small chisel. It's out now with no damage to the manifold. Funny thing is, when I inspected the remnants of the tube and the inside of the hole in the manifold, it just looked like regular metal, no nasty corrosion or anything like I was expecting.
Old 08-30-2017, 08:08 AM   #24
flatford8
flatford8's Avatar
I have quite a few 8BA's, I was always concerned about them staying in tight after having taken them out. Not the case with yours I guess...... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 08-30-2017, 10:02 AM   #25
tubman
tubman's Avatar
I know exactly what you're saying. I had to "JB Weld" the last one into my Canadian Merc aluminum manifold because it was so sloppy.
Old 08-30-2017, 10:25 AM   #26
Lanny
Lanny's Avatar
Denny, so did you try heating it and then melt some candle wax (has to be paraffin wax).
I have got some very stuck metal parts loose with the paraffin wax method.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
