Old 02-05-2016, 04:46 AM   #21
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Default Re: Marvel Mystery Oil Question
Originally Posted by Bob from Northport View Post
Several out there indicated they use MMV in their gas tanks to combat the ethanol problems. I know it offers top end lubrication for an engine, but what possible use could it have to remove or correct the ethanol problems in the fuel??
Thanks!!
Using Marvel Mystery Oil replaces lost lubricity that the ethanol causes and reduces the wear on the engine. Also, the introduction of the ethanol increases moisture content thus corrosion. MMO helps prevent the corrosion caused by moisture.
Old 02-05-2016, 05:44 AM   #22
reggiedog
reggiedog's Avatar
doesn't Sea Foam do the samething
reggiedog is offline   Reply With Quote
Old 02-05-2016, 05:48 AM   #23
Mike V. Florida
Yup! but he asked; "Several out there indicated they use MMV in their gas tanks to combat the ethanol problems. I know it offers top end lubrication for an engine, but what possible use could it have to remove or correct the ethanol problems in the fuel??"
Old 02-05-2016, 08:28 AM   #24
carolinamudwalker
Wont any of these additives contribute to the soot and carbon build up in the combustion chamber?? When I pulled my head there was a lot of black carbon build up. Normal thinking is the car has been running rich. But I wonder.
carolinamudwalker is offline   Reply With Quote
Old 02-05-2016, 08:47 AM   #25
Terry, NJ
Terry, NJ's Avatar
You're dealing with over 90 years of pretty satisfied customers. If you have carbon building up in your engine, you're running too rich! Somewhere, if my memory can be trusted,I've heard MMO helps with carbon build up.
Terry
Terry, NJ is offline   Reply With Quote
Old 02-05-2016, 09:40 AM   #26
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by tbirdtbird View Post
i feel as though as long as you are adding some type of top cyl lube you will be OK. This will lube your valves too. Whether it be MMO, SeaFoam, ATF, it may not matter. If your choice works for you then go for it!
I agree and have added various oils. I usually use 4 ounces of MMO to 10 gallons of good gas in my Model A and Studebaker, but have gone stronger with my Cub Cadet and added about 6 ounces of motor oil to 5 gallons of good gas.
Old 02-05-2016, 01:09 PM   #27
Royce P
Royce P's Avatar
What about following Ford's instructions? That works for anyone who tries it. You put gas in the gas tank. Oil, on the other hand, goes in the crankcase. It really is that simple.
Originally Posted by harleytoprock View Post
What about 2 cycle for extra lube? It's made to mix with gasoline, lubes internal parts and then gets burned.
1910 Touring
1914 Touring
1915 Touring
1917 Torpedo Runabout
Royce P is offline   Reply With Quote
Old 02-05-2016, 01:25 PM   #28
Prawbly
Prawbly's Avatar
Send a message via AIM to Prawbly
My father always used castor oil for upper lube in all his race cars. I still love the smell.
Prawbly is offline   Reply With Quote
Old 02-05-2016, 01:55 PM   #29
Willie Krash
Willie Krash's Avatar
I've used MMO since the 60's. Same measure as Tom.
It works and is much cheaper than fuel stabilizers that I do use when the car is laid up for the winter.
I had a type II VW (bus) and they are notorious for burning valves, particularly #3.
When it was time to sell the first thing the buyer wanted to do was a compression test.
All 4 cylinders were the same...! He asked how that could be. Top oil baby, don't leave home w/o it.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 02-05-2016, 03:48 PM   #30
Tom Wesenberg
They used to sell glass jars that mounted to the firewall or inner fender, then a thin line ran to the intake. You could adjust the rate at which oil dripped into the line for upper cylinder lubrication.
Old 02-05-2016, 08:22 PM   #31
Pete
Originally Posted by Y-Blockhead View Post
Sure, throw a little Blendzall in there if you like the smell of burning castor beans...
I go along with the Blendzall...Good stuff.
It is designed to mix with gas and stay in suspension.
All of the suggestions so far seem to work fine.
All of the various liquids have a distinct smell out the tailpipe.
Maybe that is why the wide difference of mixtures used.
Old 02-05-2016, 09:35 PM   #32
H. L. Chauvin
Our very poor ancestors knew more wear and ridges occurred at top of cylinders.
To prevent same, they always added always top cylinder lubricant.
Today, everybody is rich, what "difference " does it make?
H. L. Chauvin is offline   Reply With Quote
Old 02-05-2016, 09:57 PM   #33
H. L. Chauvin
Thomas was wise not to believe all the others ...... he had day to day "experience" with his former Model A Mortals ...... long live "Doubtful Thomas" ...... a Model A Hero indeed.
Old 02-05-2016, 10:24 PM   #34
tbirdtbird
"What about following Ford's instructions?"
so you are saying that Ford owners in the 30s, 40s, 50s etc had ethanol pollution in their gasoline.....some seem to be having trouble following this thread. all too often here the main point is totally missed
'31 180A
tbirdtbird is offline   Reply With Quote
Old 02-05-2016, 11:08 PM   #35
jm29henry
jm29henry's Avatar
I use marine stable the blue one it actually states treats ethanol fuel
jm29henry is offline   Reply With Quote
Old 02-05-2016, 11:27 PM   #36
Mike V. Florida
Still do ;
http://www.ampcolubes.com/
Old 02-06-2016, 10:10 AM   #37
Royce P
Royce P's Avatar
There are gullible people who are willing to spend money buying something that does nothing. Sea Foam and Marvel Mystery Oil are nothing but scams perpetrated on the unsuspecting by the unscrupulous.
1910 Touring
1914 Touring
1915 Touring
Old 02-06-2016, 10:19 AM   #38
reggiedog
reggiedog's Avatar
Royce P
I didn't start this thread Bob from Northpoint did yes I have a few post on here that's it
Reggie
Old 02-06-2016, 01:15 PM   #39
Fred K-OR
Fred K-OR's Avatar
Must be a lot of guys "snowed in" today!
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 02-06-2016, 02:31 PM   #40
tbirdtbird
I think it is high time for a Senate hearing on these horrible scams!!!!
'31 180A
