Old 01-01-2016, 06:29 PM   #21
HCO41
Default Re: Grit Blast Media Recommendation
I am currently using "speed bead" from TP Tools in Canton, Ohio. Cleans faster than glass beads with same fine, primer ready finish. Hope you got a vacuum with your new unit. Below is a link to TP Tools abrasive section of their catalog. Click on "most popular" abrasives, then on selected medias to review their characteristics and cost. Shipping is a killer!
Try this: http://www.tptools.com/Abrasives-and-Accessories.html
Howard
HCO41 is offline   Reply With Quote
Old 01-02-2016, 12:07 AM   #22
outlaw
At work we have standarized on medium glass beads. Over all it does a good general purpose clean, & leaves metal with a dull frost or sheen look. We buy ours from Grainger. Ballotini is the brand name. The grade is 70-140 & is a part # 2w580. If you are cleaning really rusty stuff you might wish to go with their coarse glass beads part # 2w765 wich is a grade 60-120. Either comes in a 53# 5gal pail. For really heavely rusty metal I would wire wheel the parts first to save the glass beads (they will turn to pumis over time) & keep the cabinet from "dusting up" with rust dust. Wipe down with thinner to clean the dust that will stick on the metal. Bill
outlaw is offline   Reply With Quote
Old 01-02-2016, 06:05 AM   #23
flatmotor40
flatmotor40's Avatar
I get my blasting stuff from Tractor Supply.Cheapest any where and it last longer than play sand
flatmotor40 is offline   Reply With Quote
Old 01-02-2016, 07:25 AM   #24
john in illinois
john in illinois's Avatar
Howard I have always used glass beads. I tried the TP speed beads and they work much faster with the same fine finish as regular glass beads. I use 1/2 a 50lb bag per fill. so a bag lasts 2 or 3 years.
I used to restore early Triumph motoryrcycles and I tried walnut shells for aluminum but never had much succes plus they bwere hard to clean out of cabinet. When I would clean spark plugs with beads a stray walnut shell would end up stuck in plug.
John
john in illinois is offline   Reply With Quote
Old 01-02-2016, 07:38 AM   #25
39portlander
39portlander's Avatar
John
My 960 patriot came with the scat magic, I have switched to the speed bead, similar results and a lot less dust. As for aluminum, I got the soda master attachment.
39portlander is offline   Reply With Quote
Old 01-02-2016, 04:19 PM   #26
robert dick
for very heavy blasting i use black beauty but for most of my work i use a product called potters beads, very fine and does a beautiful job on delicate parts.my primary pressure is 90 psi.
robert dick is offline   Reply With Quote
