Old 10-20-2015, 10:34 AM   #21
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: 680 oil report
Originally Posted by Mitch//pa View Post
i find it amusing that none of the suppliers who participate on the forum never comment on what they sell for 600W......it's their secret ace in a hole
Reminds me of MARVEL "MYSTERY" OIL! I detest MYSTERIES, I have to know a ALL the FACTS.
"THEY" won't divulge the ingredients in gear oils, for fear we would concoct our own "BREW".
The Dog suggested SORGHUM SYRUP, to slow down the gears, for SYNCHRO-LIKE shifting He quoted Jackie Gleason, "HOW SWEET IT IS"!!! Dogs are SMART, Buster T. woke me up 3 times, with his COLD nose, to alert me that my Jitterbug Phone was playing its' "CHARGE ME" tune
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-20-2015, 01:36 PM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
If it's popping out of high gear I'd check the flywheel cover alignment, as well as worn input shaft and bearings. Maybe someone left the shims out for the top two bolts on the cover.
Old 10-20-2015, 02:13 PM   #23
1930artdeco
1930artdeco's Avatar
I know the shims are there because I asked about them when we put the engine back together. This is the first she has done this to me and dad can't remember her doing it-but then again he is old. Where does the input shaft get worn? Everything looked good when I took the tranny out.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-20-2015, 04:01 PM   #24
Brentwood Bob
One wear point for the input shaft is at the pilot bearing interface.
Bob
Brentwood Bob is offline   Reply With Quote
Old 10-20-2015, 04:17 PM   #25
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
I have been using the 680 products in my A transmission and banjo for over 13 years and 26,000 miles. I have used both Mobil Meropa 680 EP ISO and Chevron Gear Compound 680 EP ISO. My transmission shifts like a dream. I would not use anything else.
Dick M is offline   Reply With Quote
Old 10-20-2015, 04:50 PM   #26
mrtexas
mrtexas's Avatar
No big secret. It is probably Mobil 600w, iso 460 or iso 680. All will work. The iso oils are better in that they have additives.
Funny old myths about what it was like in the good old days. When the refinery where I worked installed a unit to hydrotreat heavy lube oil and started delivering higher quality hydrotreated oils with the key properties the same or better, customers complained it wasn't the same old dark stuff anymore. It looked more like honey. I want my Maypo!
mrtexas is offline   Reply With Quote
Old 10-20-2015, 04:53 PM   #27
mrtexas
mrtexas's Avatar
Mike
Likely from worn bearings in the trans or misaligned bell housing or something else worn out. Shaft can be turned down and a small ID bearing installed.
Old 10-20-2015, 05:14 PM   #28
1930artdeco
I don't remember any wear on the input shaft, but then again I wasn't looking for any either.
Mike
1957 Country Sedan
Old 10-20-2015, 05:14 PM   #29
Mitch//pa
probably is the key word.... so its still top secret
Old 10-20-2015, 06:08 PM   #30
John Stone
John Stone's Avatar
Saw a flywheel that had a little nick in the hole that holds the pilot bearing. Caused the bearing to be distorted and would throw it out of high. Strange things happen.
John Stone is offline   Reply With Quote
