Old 05-29-2015, 07:55 AM   #21
G.M.
Default Re: Flex fan?
Originally Posted by flatheadfan View Post
Kevin-
I understand your thinking but I am not so sure the thrust and/or load change (if any) would be a problem with a replacement fan. As I recall, the Ford standard generator with a bolt-on fan was a four blade critter. A six blade fan (extra cooling), was optional and didn't require a modified or replacement generator to handle the greater thrust/load change created by the heavier fan. Still, you have a point that might enter into the situation and is worth considering.
Thanks
Tom
The six blade Ford fan don't do much to improve cooling, it just makes a LOT of noise. G.M.
www.fordcollector.com
Old 05-29-2015, 08:04 AM   #22
48 coupe
48 coupe's Avatar
Did you ever consider an electric ? I have one on my 48. I think it's from a 90's Buick. 12 volt. It may not suck as much as Flatford8 's, but it works for me.
48 coupe is offline   Reply With Quote
Old 05-29-2015, 09:22 AM   #23
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by flatford8 View Post
My '50 fordor has a flex fan and it sucks like a sailors sister on Saturday night........Mark
You wouldn't happen to have a picture of that sailor's little sister, would ya? DD
Click Links Below __
T5 W/TORQUE TUBE
