Old 07-06-2015, 11:06 AM   #21
J Witt
J Witt's Avatar
Default Re: pitman arm
Just installed the shortened arm from Snyders. I like the steering feel a great deal over the stock one. The wheels still turn the same angle left and right as before, just requires a bit more steering wheel rotation, as the mechanics dictate. Just a matter of taste and muscle, I guess. 34 psi in the tires.
I could not get the repro arm to tighten up on the sector shaft. Torqued it to about 100 ft-lbs and the bolt snapped, still never was completely tight. Solved this issue by coating the sector shaft with stud lock grade loctite and giving it 24 hours to set up (with a new retaining bolt, of course).
I overhauled the drag link with new steel ends. Steering wheel centering not a noticeable issue for me. Overall, I like it, but some revision to material, process or tolerances needs to happen to allow the arm to clamp down properly.
John
Houston, Tranquility base here. The Eagle has landed.
J Witt is offline   Reply With Quote
Old 07-06-2015, 11:29 AM   #22
mshmodela
mshmodela's Avatar
In terms of steering, after I installed shocks the 1.25" of steering play was hardly an issue... At this point I cannot imagine trying a short arm... at least on my car.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 07-06-2015, 03:53 PM   #23
MikeK
MikeK's Avatar
Originally Posted by katy View Post
So, what is the length of the stock pitman arm? And, how short is the shorter version? . .
The original arm is 7.5" from ball center to sector shaft center. The shorter arms are 6.0".
Simple math, whatever steering wheel force you need to grind the tires into a turn while not rolling (parking) you will need 20% less force (torque) on the steering wheel with the 6.0" arm. You will also need to move the steering wheel more to make the same change in direction while driving. To me a shorter arm feels like you are driving a bus. Major wheel movements to make minor directional adjustments. I got rid of mine, went back to stock. Also, whatever total free play you have in the wheel with the stock arm will increase proportionally with a shortened arm.
Some 7-tooth steering boxes may not have sufficient angular range to run the steering linkage lock to lock with the shorter arm. All the 2-tooth boxes can accommodate the greater angular range required but you may notice an increase in the slight slight off-center 30-31 steering wheel while driving straight ahead. To fix that requires an adjustable (or slightly shortened) drag link.
Before the new forged shorter arms were available it was common practice to cut and weld arms to varying shorter lengths. An stock arm shortened 1" (to 6.5") will go lock to lock on a 7-tooth car and require 13.3% less force.
MikeK is offline   Reply With Quote
Old 07-07-2015, 09:39 AM   #24
katy
katy's Avatar
Thanks to MikeK for the info.
Old 07-08-2015, 04:59 AM   #25
Mike Crehan
Trying again
There you go Updraught I finally did it.
Mike Crehan is offline   Reply With Quote
Old 07-08-2015, 06:14 AM   #26
updraught
updraught's Avatar
Hey Mike,
Glad you got it sorted. Just had my own computer drama where the cable fell off the disc drive (a known problem on this model). Thought I'd lost everything for a bit...
That pitman arm looks impressive.
I've just bought a supposedly rebuilt RHD 1929 steering column which looks like it has a 1932 two tooth type box put on it with a pitman arm that looks somewhat like that.
I guess the idea is that the ball can be changed which it can't in the Model A box. I'm hoping it will work out.
A shortened one would be a touch of luxury tho ....
updraught is offline   Reply With Quote
Old 07-08-2015, 06:56 AM   #27
updraught
updraught's Avatar
Some pictures of my steering box.
Wonder whether anyone else has one like this?
