pitman arm Need a shortened pitman arm for better steering. Need a source to buy. Thanks
Re: pitman arm All the big parts houses have em now, Try Mikes or Snyders, I am pretty sure they have new ones now.
Re: pitman arm IN the Winter 2010 Issue of the Model A Times we reported on Snyder's new short pitman arm. Not a modified original but brand new.
Re: pitman arm Contact Snyders, you won't be disappointed ! Wayne
Re: pitman arm Can you explain why you would want to use a shorter arm? I've used longer arms in the past to make the steering quicker, I'm not sure with vintage boxes why you would want to make it slower?
Re: pitman arm Quote:
Re: pitman arm Ok. Thank you.
Re: pitman arm You may need an adjustable drag link to center the steering.
Re: pitman arm Hello Thomas,
You need to know the shortened pitman arm is not a cure for poorly maintained steering components, as mentioned you will most likely need a adjustable drag link. |
Shortened Pitman Arms only come LHD we have to heat them and twist them to face the "right" way. A dissapointment! Contact Snyders! Not likely. They seem to not want to deal with anybody outside US now. Their new website has a "Contact Us" form where a phone number is required. Our telephone numbers have more digits than those in the US. The site won't recognise them and won't allow the message to be sent. Seems dealing with Snyders has just been taken off the table. Can't understand their business smarts cutting so many customers adrift.:eek: |
Re: pitman arm I rebuilt my steering box with the needle bearing sector housing,installed a shortened pitman arm, and installed nylon inserts in the tie rods and pitman rod. no need for an adjustable pitman rod. You wouldn't know it was the same car. Steers wonderfull and light. I love it.
Re: pitman arm If you have access to a friendly machine shop then you may be able to make one which is what we have to do with a number of the less prolific makes of car. Ideally you want a piece of EN24T bar so that you can have the structure running lengthways down the finished arm. I get the thing wire cut (spark eroded if you prefer) in plan and then elevation. The wirecutting will produce all splines and tapers probably more accurately than the original. Then I use a linishing belt and a die grinder to take off all the square edges so it looks like the forged original that is being replaced. The Delahaye / Delage ones we did last year took me about an hour each on top of the machine shop time. No doubt a Snyders one will be cheaper but I wouldn't want to be heating and twisting it before using it
Re: pitman arm I've tried to upload a photo but it all just seizes up once I've uploaded and hit the close this window button.
Re: pitman arm I bought mine from Brattons. Good quality but it increases the turning radius. Difficult in tight spaces.
Re: pitman arm Didn't hurt the turning radius on my roadster. I still turns lock to lock and is better than the power steering on my Lincoln if the car is in motion. First Model A I ever had that returns after a turn, but I had 7 tooth steering and changed that to the 56 Ford at the same time as the shorter arm. Very easy to drive now. Next will be a synchro so the bride can drive it. You will love it I'm sure.
http://www.fordbarn.com/forum/showth...ading+pictures PS. I use IrfanView http://www.irfanview.com/ to resize photos. |
Re: pitman arm So, what is the length of the stock pitman arm? And, how short is the shorter version?
Asking because I'm new to fixing Model As. Owned and drove a few of them years ago but didn't do much fixing, just drove them and replaced parts from an auto wreckers when parts were needed. Right now I'm working on a "refurbished" '31 CCPU that I need to get ready for the safety inspection before I can insure and license it. |
| All times are GMT -5. The time now is 04:43 AM. |
