Old 05-22-2014, 10:58 AM   #21
Nodakwalleyer
Default Re: New block update 3.
Just seen some pics of new block machined, looks great! Really coming together nicely!
Nodakwalleyer is offline   Reply With Quote
Old 05-22-2014, 11:05 AM   #22
Tod
WOW! That was a fast response. I just finished sending out 3 pictures to about 20 people.
Tod
Tod is offline   Reply With Quote
Old 05-22-2014, 11:10 AM   #23
Mitch//pa
how do i get the pics???
Old 05-22-2014, 11:15 AM   #24
Tod
Email me at blockheads2014 at yahoo dot com
Tod
Old 05-22-2014, 11:15 AM   #25
392roadster
Wow!!! Sounds great!!!...... Price? Pics? Avail.?
392roadster is offline   Reply With Quote
Old 05-22-2014, 11:21 AM   #26
Dodge
Tod,
Pictures look great. It looks like you've really got a handle on it. And guys, this is coming
along a lightning speed when know what this takes.
Keep up the good work. This is very exciting.
Dodge is offline   Reply With Quote
Old 05-22-2014, 11:58 AM   #27
G Baese
G Baese's Avatar
Tod,
Thanks for the pics! A new Model A block is no longer a dream, its an impressive reality and this is the guy that made it happen.
Best regards,
geary
G Baese is offline   Reply With Quote
Old 05-22-2014, 12:17 PM   #28
Russ/40
Russ/40's Avatar
Looks like a very clean casting. Your moving right along at a break neck pace!
Russ/40 is offline   Reply With Quote
Old 05-22-2014, 12:48 PM   #29
Tod
It's a pretty nice casting considering the mold and cores were old and just made for test fitting, as well as not even having a gating system set up for it.
The pace is not nearly quick enough for me.
I have to finish the rear of the block so I can mount a flywheel housing, and then I need to drill and ream the lifter holes, main oil galley, bore the cam and crank, and drill the oil galleys from the main galley to the crank. I also need to do the oil pump hole. A few more days, I suppose, and then I can hand it off to Prus Jr. to build for me. Hopefully, it will run right off the bat.
Tod
Old 05-22-2014, 12:56 PM   #30
Tom Wesenberg
Tom Wesenberg's Avatar
I know of a good original 1928 Phaeton that could test drive that new engine for you.
Old 05-22-2014, 12:59 PM   #31
Tod
And just who might have that? Let me guess - your wife's husband.
Old 05-22-2014, 01:02 PM   #32
Tom Wesenberg
Still single, but if a wife comes with the new engine, that would be OK.
Old 05-22-2014, 01:15 PM   #33
Tod
I guess we could start a side business "A-Harmony dot com." We have all the hot babes. Must love cars.
Old 05-22-2014, 02:32 PM   #34
tbirdtbird
The pix are awesome, Tod. We are salivating here in my shop.......
'31 180A
tbirdtbird is offline   Reply With Quote
Old 05-22-2014, 02:33 PM   #35
34 FORDOR
34 FORDOR's Avatar
Tod thanks for the pics and update. Guys this block is looking real nice Tod is doing a great job, he has the skills and contacts to pull this off.
34 FORDOR is offline   Reply With Quote
Old 05-22-2014, 04:28 PM   #36
Tod
We had to knock off a little early today because my grandson is "graduating" from pre-school or kindergarten, or whatever it is, this evening. Since we shut down production early I had some time to work on the back end of the block. I was able to get all the holes drilled and tapped and set a flywheel housing against it. Looks good at first hurried glance. I had to leave so I will have to finish up in the morning and bolt it on. That will be the last part to bolt on before moving on to the cam, oil galley, and then the bottom.
I'll send out a round of pics when everything is bolted on including a head.
Tod
Old 05-22-2014, 04:36 PM   #37
Mitch//pa
Yea mon"
Old 05-22-2014, 05:23 PM   #38
tmiller6
tmiller6's Avatar
Tod,
I got the photos when I checked my email at work; I am sitting home recovering from eye surgery and you probably got my away message. What I saw in the photos is darn exciting. That is one high quality casting and the machine work is beautiful. I can't wait to see this engine run.
tmiller6 is offline   Reply With Quote
Old 05-23-2014, 06:06 AM   #39
motordr
Looking good, great job Tod!
motordr is offline   Reply With Quote
Old 05-23-2014, 06:23 AM   #40
C26Pinelake
I must say I am truly impressed with your skills and professionalism. I can't wait to see the finished product.
Wayne
C26Pinelake is offline   Reply With Quote
