Old 05-02-2013, 10:43 AM   #21
37 Coupe
37 Coupe's Avatar
Default Re: Where/how to mount factory oil filter on a 59ab
Roy Nacewicz has recessed nuts. Well I should say in his catalog,but his slogan is "We have your nuts"
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 11-06-2021, 01:36 PM   #22
Ckrivin
Ckrivin's Avatar
Anybody used Inline Tube or Classic Tube Oil lines? If you have do they fit? How about those amazing nuts - what size/ thread #? ALSO the .060 restrictor, same question what size/ thread?
THANKS!
Craig
89, 69, 53, and 40 Mercs
Ckrivin is offline   Reply With Quote
Old 11-06-2021, 10:54 PM   #23
cas3
Just make your own lines from !/4" brake line from the store. The .060 restriction can be made by brazing up the end of a fitting, and drill it with a 1/16 " bit, roughly the same thing. Fittings are all 1/14" male pipe thread, and 1/4" female flare like a brake line, all available at the store
Old 11-07-2021, 08:17 AM   #24
19Fordy
19Fordy's Avatar
Here's studs I used to mount the filter canister on an 8BA with early style heads.
I removed original head bolts one at a time and installed them one at a time.
Those recessed nuts are best idea for studs.
